Rockbox for iBasso DX90 dual boot with Mango (Stock Firmware)
post-10909773
Post #451 of 1,310
napka
As a mac user, i'm glad folder is not default .rockbox, i don't have to type 'open /Volumes/DX90/.rockbox' to open it now, but wouldn't it cause lot of problems with documentation, wiki, hardcoded paths, etc?
post-10910411
Post #452 of 1,310
headwhacker
Originally Posted by napka /img/forum/go_quote.gif
Is there a real reason for all those subfolders instead of /rockbox instead of /app_rockbox/rockbox and /bin instead of /app_rockbox/bin folders? It may be hard to explain for new users, for example all docs and rockbox wiki refer to /.rockbox.
the rockbox folder stil exist and all data still stored there and works the same as before. The files in apps are what use to be in the firmware which are not accessible before. You don't need to touch it just like before.
Any interaction should still be done in the rockbox folder.
It's not the last version btw :)
I must have miss the latest link. Anyway, same as before you can drop it into the rockbox folder. :)
The only change will be the update process. Instead of flashing the full firmware you only need to overwrite the apps folder with the latest version. Hence, the reason I put it in separate folder.
The benefits of this change as I see it are the following
1. Updates can be applied quickly. You don't need to flash the firmware every time a rockbox update is available.
2. You don't lose data on both Mango and Rockbox every time you apply the latest update.
3. The rockbox zip folder is considerably smaller which is much quicker to download.
If you have any other ideas, you are pretty much welcome to share
Reactions: paulus germanus
post-10910424
Post #453 of 1,310
headwhacker
@Cholero and I have been discussing about the folder location. I am a Mac user and for Unix/Linux as well. So I know how painful it is looking for hidden files or folders in finder.
I don't think it's going to cause any issues with the paths or documentation. Like I said the stuff that you save personally like database and settings still goes to the rockbox folder.
post-10910849
Post #454 of 1,310
musictoear
I Have a question and the question is:  Where is the ibasso site download for the firmware?  The lastest in their website is back in July.  Confused.
post-10910871
Post #455 of 1,310
headwhacker
Are you referring to the stock iBasso firmware or the patched one? Ibasso's firmware has not been updated since July.
post-10910912
Post #456 of 1,310
musictoear
thank you for your answer.  It was a patch and i did not get that.  Thank you, now i understand.  It is to make it easier down the road to upgrade rockbox.
post-10910918
Post #457 of 1,310
headwhacker
no problem. iBasso's main site seems to have issues lately and I thought you are asking about the official FW.
post-10911197
Post #458 of 1,310
cholero
Congrats for the new file structure, having the app on the sdcard. This is the way that makes sense and the way I want to change the build mechanism on the official rockbox page. So everyone can just download the newest zip and extract it to the internal drive (once he has the firmware patched). This is the future.
post-10911267
Post #459 of 1,310
kamson
@headwhacker I have a problem with the new version - it won't turn on (hangs on DX90 white logo screen) when hold button is off. Works ok, while the switch is on.
post-10911364
Post #460 of 1,310
headwhacker
Does it hang when you previously booted rockbox after selecting it from the boot menu? Does it boot fine after you boot Mango?
I may have uploaded an earlier build of the patched FW.
Could you download The patched FW again and just flash the update.img file. Try the one from google drive
post-10911392
Post #461 of 1,310
kamson
After reflashing img from google drive everyrithing works as it should. Thank you very much headwhacker!
post-10911518
Post #462 of 1,310
headwhacker
Great, the link to Mega should work as well they are the same file.
post-10911600
Post #463 of 1,310
headwhacker
  I really need to Bookmark. In Roskboks0.4.9 they are created but can not be played. Help please
I just look at this now It works for me. How do you play bookmarks? I can press and hold the play button while at WPS screen and select Bookmarks from menu then list bookmark.
post-10911689
Post #464 of 1,310
iBeyerX90-COP
I don't see any time/date setting : this is a dx90 limitation ? Just wondering, but I don't really care :wink:
post-10911763
Post #465 of 1,310
headwhacker
That's right, both DX90 and DX50 don't have a real-time clock. So it cannot display time.
