ccschua
- May 19, 2008
Nice job. I really admire your diy into the volt reg.
I have emailed audio-gd about the volt reg as well.
So far, I found the Sun vocal is slightly more forward and more dynamic. After sometime, I just pop back the OPA Earth.
Originally Posted by Pricklely Peete /img/forum/go_quote.gif 30US is about as cheap as you'll find for a glass toslink including shipping...the only other place I can think of off hand is BlueJeans Cable but I don't know if they have a glass toslink....I'll have a look and see... A disturbing note with my Zero running SUN in the H/Amp and the reg HDAM in the dac section...once the OPA's burned in I noticed the bass had leaned out considerably...almost like the volt regs could not deliver enough juice to the current hungry SUNs...I don't know for sure if this the case. Alex is redoing his volt reg section in the H/Amp section and I had talked with CC about a sep power supply and volt reg for all 3 HDAMs...anyway when I pulled the SUNs from the H/Amp section and put the LT1364's back in the bass came back to what it was before....weird. Further investigation is needed and Pench and I are in the middle of that right now... Alex do you know the max current the stock regs on the H/Amp board can supply ? I think the dual channel SUNs are drawing what...close to 88 ma ? The LT's maybe 1/4 to 1/3 of that...although that may be incorrect. In any case I think the stock Zero can run 3 HDAMs but will need help in some form to deliver the current needed to sound great to those current hungry HDAMs.. I do have a volt reg board and transformer on the way...so I'll be able to test this theory for real in a couple of weeks. I also wasn't keen on the SUN's voicing...I found I much prefer the neutral presentation of the Earth/LC module. With the heavily modded Zero the voicing of the SUN once it had 75 hours to cook wasn't my cup of tea and found the LT1364's a much better match to my ears, but also the problem talked about earlier in the post. Can people post impressions of the SUN module in the DAC section please so we can get a baseline of it's SQ's vs the known Earth/LC HDAM. For now I have to keep my Zero as is for the final leg of tests before the mod kit is released so I can't pop the SUN into the dac section for a little while yet Thanks guys !!!! Peete. |
