Trax416
- Aug 29, 2008
Sounds good. I might go with the OPA627 just because I am going to move the ZERO around a lot (toss it in a bag when I go on a trip for example), and the OPA-SUN bouncing around on it's extension inside the casing might cause an issue.
Thanks for all the help. So All I do is just pop off the old chip with Pliers, then push the OPA627 into the socket? Will it click into place? or do I need to do anything more to lock it down.
Originally Posted by ScottieB /img/forum/go_quote.gif The OPA627 is a "traditional" opamp chip - one that has been found to sound pretty darn good in the DAC section of the zero (see page one of this thread - Penchum's rreview). The OPA Sun is a "discrete opamp" - meaning an opamp with components more geared toward audio specifically. Check it: н¨ÍøÒ³ 1 Make sure you read all the way through Penchum's review, though. There is a TON of info there. Woo-hoo 100th post (only took me 2 years!) -- and why is it I always seem to do so much LABOR on labor day? Thought it was supposed to be a day off! Meh... ![]() |
