d-cee
- Apr 14, 2006
pre-amps are usually used in conjunction with power amps such as mono blocks. these have no volume control of their own and only one input and so a pre-amp is required to control the volume and usually as a source selector, but not always
in headphone world, most all headphone amps have integrated volume controls so you wouldn't use the Zero's variable outputs, just it's straight line out. having multiple volume controls in the signal usually is a bad thing.
Originally Posted by arteom /img/forum/go_quote.gif this is maybe a stupid question, keep in mind i am a newb; what would be the benefit of using the Zero as a pre-amp for an amp? Is it simply to listen to the sound signature of the amp? Like for example to listen to the the tube sound of the mkIV. Wouldn't the problem of feeding current to a current hungry set of cans be solved by a unit such as the Zero? I was considering getting an amp before the Zero arrived to my doorstep, but now I can't really see the benefit of getting one. -arteom |
