dacavalcante
- Oct 13, 2006
Well today I have tested my Zero DAC on a PS3...... the sound was perfect normal......
On PS3 config I set it to use 88khz and 188khz also....
the problem is.... I really don't know what was the frequency it was using..... because it's auto selected......
Tested Company of Heros and a car game that I don't mind the name now......
My friend didn't had any show or studio recording... this would be better because I would know for sure the frequency used...
What do you think ?
DaC
Originally Posted by tinseljim /img/forum/go_quote.gif PS3 is the best bet to try CD, DVD and Blu-Ray for various kHz. Although I'm not entirely sure if it resamples for two-channel audio. I don't believe it does. Anyone else? As far as Windows I remember some posts about people with the audiophile have compatibility problems. After a quick search this is the first hit (though not sure if it's referring to your card): "Dont buy this card if you run vista I just recently purchased a new pc with Windows Vista and M-audio is very slow in releasing new drivers. ASIO drivers work with the card but is limited. You cannot run more than one application using the driver at a time and most other applications will not work. My PC has no audio. My Studiophile monitors hiss but nothing beyond that." I would say your best bet, if you still have problems, is to call your nearest music store, one that has recording equipment for sale. Tell them about your problem and I'm sure they'll be able to recommend something. Hope it sorts itself out soon! James |
What do you think ?
DaC
