REVIEW: Unique Melody Merlin - hybrid dynamic/balanced armature custom IEM
post-8540373
Post #841 of 1,290
Personnel Jezuz
That makes sense. Small size is sometimes really important.
The only thing I will recommend is that you be sure to watch the output impedance. The Merlin dips rather low at certain frequencies, and if you are using an amp with a 5 or 10 ohm output impedance (for example) that is likely to cause some changes in the frequency response. So whatever amp you choose, you really want a 1 ohm or lower impedance if at all possible, to ensure you get the proper response as intended by UM. This applies to headphone amps in general but it's especially critical with the Merlin.
Ahh that might explain the difference in sound moving from different sources and amps...apart from resolution and clarity of course. Going to have a few tests now and see what I find. Thanks for the advice Project!
post-8540568
Post #842 of 1,290
Cotnijoe
Sponsor: iFi Audio
Formerly with Unique Melody
Baltimore
Baltimore
hey guys! im rly interested in getting the Merlins as they seem amazingggg...but just how much bass does it have? I do like a little bit of bass boost but too much rly doesnt work with me. How would the bass compare to the likes of V-Moda M80 or AKG K550 or stuff like that?
post-8541756
Post #843 of 1,290
piotrus-g
Member of the Trade: Custom Art
Poland
Poland
I just recieved my testing pair of AKG K3003 and I think with bass filters it sound really close to UM Merlin.
post-8549492
Post #844 of 1,290
Emospence
The dynamic driver is tuned specifically for the lows?
post-8549499
Post #845 of 1,290
Sorensiim
Uhm... yeah, that's its purpose. Dual BA's for higs, dual BA's for the mids and the dynamic driver handles the lows.
post-8549953
Post #846 of 1,290
Emospence
I see..
How about the Aurisonics AS2s, any Merlin users have heard those as well?
post-8552135
Post #847 of 1,290
Emospence
Are these phones vented or sealed?
post-8552276
Post #848 of 1,290
ValentinHogea
Vented... But the vent is not linked to the inner-ear, therefore no big difference on the seal/noise isolation.
post-8606957
Post #849 of 1,290
88King
One of my iem have a developed a small hole lately, there was a crack when I fist got it, and it since got worse and I can now see the driver through the hole. Does any one know if there is a easy way to fix this without sending it back to UM Lab?
P.S. The area around the conector have developed a milky colour,  does anyone know why?
Many thanks
post-8606999
Post #850 of 1,290
ValentinHogea
That looks nasty!
You should really contact Unique Melody, moisture might have gotten in and started to corrode the drivers. It's still under warranty so.. contact them!
(If you wanna be "cheap", I think clear epoxy-mould should cover it up just fine.)
post-8607076
Post #851 of 1,290
maguire
I would definately contact UM.......
post-8607233
Post #852 of 1,290
UniqueMelodyAus
Member of the Trade: Unique Melody Australia
Yep, I would definitely contact UM too...
Drop us an email with your UMG order ID...that needs to be fixed asap.
post-8642970
Post #853 of 1,290
PsychoBananas
Just got my Merlins back. Fourth time. Quite happy this time. All I can say is get a deep impression and ask for longer canals, they were so short they could have been universals.. Finally satisfied. 1 year after original shipping date.
post-8666284
Post #854 of 1,290
Wobble
Hey i finally just shipped off the Merlins i bought from DannyBai today for a reshell. Does anyone have a good recommendation for a good amp to better the listening experience when pairing these with an iPhone 4S? Or is that even necessary?
post-8666732
Post #855 of 1,290
Personnel Jezuz
Personally, I get just as much satisfaction from my iPhone 4 as I do with my home rig for my merlin's. If you're out and about, I see no benefit in the extra bulk at all and the iphone4/4s is a pretty competent source too. I use my merlin's as part of my main desktop rig and portable rig i.e. I was sick of tired of big headphones and carrying around lumpy amps.
