Cya|\|
- Apr 17, 2009
I received, with my Sparrow, a 24/96 USB module to try. I pulled the Fun out of my speaker rig to compare it to the original with headphones, and while the difference wasn't large, the 24/96 module seems to be a tad smoother/less harsh. I think the overall AD1852/DIR9001/Earth combo is, overall, a bit harsh at this level with bright cans. I understand why now many manufacturers of low-end gear tend to make their amps and the like a bit rolled-off, such as by using the WM8740 and/or through the design of the output stage, as it masks this. I haven't played with the "soft" setting jumpers in the Fun this time, but if they behave like they did in the Compass, engaging them gives quite subtle results that might be worth trying if harshness is a problem. I recall Zanth saying, about the Compass, that he enjoyed using it at work with the most rolled-off soft setting, as it was very relaxing to listen with.
Isn't the 24/96 module the default one? By the way, could u do a comparison between the sparrow and the fun with earth opamp? I'd really like to know if the fun with upgraded opamp is better than the sparrow.
