slim.a
- Jan 8, 2009
I didn't try the Denon d5000 in the FUN, but if I had to guess, I would say that it should work fine with the default setting and Earth HDAM. I don't think it would be necessary to use the soft settings unless you are using some very bright headphones.
On another subject, I asked Kingwa if they were planning to add new modules and he said that he might add in the future the PCM1704UK dac module if there is enough demand for the FUN. The only weakness I found in the DAC is the slight "digitis" that is common to all delta sigma dac chips I have listened to (cd players and dacs costing to up to $5000). If he can provide the PCM1704UK chip in an entry level it would be very very interesting.
Originally Posted by littletree76 /img/forum/go_quote.gif I will be using my favorite headphone Denon D5000 (mod with Beyerdynamic DT880 pad to tighten the bass) with the headphone amplifier. As for speakers, I will be using Virtue Audio's Virtue ONE class T amplifier to drive a pair of Klipsch RB-51 satellite speaker and an active Boston Acoustic XB4 subwoofer. Probably Line Output (rather than DAC Output) of FUN will be used to feed line input of the Virtue ONE power amplifier. |
