Originally Posted by nautilus983 /img/forum/go_quote.gif
Hello Slim,
I have two further questions for you
1) In the post that you made on the Bada 5600 power filter, you noticed that you had to use it with the Essential Audio Tools Noise Filter to restore depth into the soundstage. However, I have noticed that you are not listing Essential Audio Tools Noise Filter in your profile - have you removed it from your system? If yes, why so exactly? I'd like to get the Bada 5600 plus the noise filter over the Supra Mains (with the noise filter I believe).
2) Now that you are using the Oyaide DB 510 and the Artisan Ultimate Silver Dream interconnects, along with the Bada power filter and the powertransplus power cord, could you describe us the difference between the PMD100 and the DF1704? Which one would you recommend?
Hi nautilus983,
I am still using the Essential Audio Tools Noise Filter along with the Bada filter (I just forgot to put it on my profile). In fact, I am so happy with it that I am thinking to buy another one later (according to some, the more parallel filters you use, the better the effect but I have to try it for myself).
PMD100 vs DF1704
As for the comparison between the pmd100 and df1704, the difference is even more obvious after the many tweaks I have done to my system.
The sound with the pmd100 is very warm (tubey like), with rich harmonics but it lacks resolution and transparency compared to the DF1704.
I am well aware that in other DACs people preferred the PMD100 instead of the DF1704. However, in the case of the dac19mk3 it is not even a matter of preference. The DF1704 is much better : it has more deep bass, a more transparent midrange and more extended highs. The soundstage is significantly bigger. As for the resolution, the PMD100 masks all the low level details (concert hall ambiance, echoes, reverb,...) that is present with the DF1704.
When listening trough the PMD100, it is like listening to a rose tinted glass. Everything is nice but all recordings sound the same (relatively speaking of course). When listening trough the df1704, it is like looking through a highly transparent glass : the music comes out raw and unprocessed. With the DF1704, some recordings are warm, other are forward, and some of them are neutral. So to me it is a more accurate filter than the relatively euphonic sounding pmd100. By the way, I think that some people like the pmd100 in the dac19mk3 because it slows transients and "rounds off" the edges of the recordings which simulates that "analog feel". However, that slowing of transients also kills the dynamics (and the soul) of the music
Whenever, I tried comparing both modules, I would describe the pmd100 as enabling a good presentation, while the DF1704 could be best described as transporting me to the event.
Overall, the DF1704 gives a more thrilling experience because it is also fastest and more dynamic than the pmd100.
However, there are 2 things to keep in mind:
1. the DF1704 needs a careful set-up : if the source, the digital cable or the power cable are not up to the task, the DF1704 can give poor results (edgy sound for example).
2. the difference I heard could be less (or more?) audible depending on the system. For instance, I have been testing this last week the Stefan Audio Art Sennheiser upgrade cable (that rosgr63 sent me to try) and I find that those differences are less audible in comparison to when I use my Artisan Silver cables throughout. In fact, since the Stefan Audio Art Cable is slower and less resolving than the Artisan Silver headphone cable, most of what I could detect was a slight tonal shift and a slight change in the soundstage. There were other differences, but they were small with Stefan Audio Art Equinox Cable.
