lwien
- Mar 6, 2013
Being that there such a variation between tip sizes by manufacturer, I'd suggest getting the assorted sizes for the first go around with the TS-400's.
Regarding the wax guard, it "may" be worth it if it doesn't attenuate the highs and upper mids. I've heard that they do tend to do that a bit.
If you have the RE-400's, I strongly suggest to try the TS-400's out. Also, if you do, please report back to let us know if you have the same experience as I.
just curious, what size hybrids do you generally use? now i'm interested in getting some ts-400's, but i don't know what size i should get. i have really strange ear canals, but generally large stuff fits me better than medium even though large stuff sometimes gives me an uncomfortable seal. but mediums usually are too loose to seal at all. also, do you think paying a little extra for the wax guard versions would be worth it?
