Inter connect cable? If you mean storm iem cable then the storm will be slightly thicker bass and a bit more relaxed mids and treble. Mids and treble will be detailed but not analitical or cold.
What tips do you recommend?
I ordered already the JVC Spiral. Any foamies worth checking?
Do the tips somehow alter the sound? I would gladly check some which reduce the slight harshness a bit (yes, I'm that sensitive) - on the sureals the 2.5 are borderline to become sibilant.
Maybe a cable would smoothen the sound even more, but without loosing details?
500 size, last like 6 months but will last ling but slightly not as tight as the first 6 months. But being not as tight will open the sound. Some will wash the comply and reuse.
Yeah,guess those might be exactly the same:
http://www.ebay.com/itm/6-S-M-L-Replacement-Earbuds-tips-for-Philips-UE-In-Ear-Earphones-/381519532186?hash=item58d456109a:g:xv8AAMXQC-tTBGak
Imo any decent amp would do the job well with these 2.5 , for me personally actually even without any external amped , it sounds good on my HTC smart phone .
Ofcouse it would be different on the pc without a decent sound card onboard , but I'm pretty sure even without the use of external amped , it would sound good on your 5th gen ipod with its on board internal headphone amp .
