Going to sell off some things... Just purchased brushed nickel asg g2.5... Probably going to sell the red asg g2.5 and my black asg g2. No need for all this foolishness.
wonder if any companies would reshell with Titanium for a price. Also, does anyone know any service that would do a custom reshell for these Universal ASG-2.5? Like turn these ASG-2.5 into Custom 2.5
All I have to say about linum + aurisonics is I hope your ear tips stay in place really securely. At least in my experience I didn't realize the weight of the cable helped to keep the IEMs in your ears. I kept having my Kickers fall out when I had linums on them...
I agree entirely with everything you said. I should have made it clear that I don't know any other non-memory wire options either.
However the memory wire on the stock wires (and most other) is just heatshink, so if you're not squeamish, you can take a razor and split it down the middle and then peel off the clear heatshrink. Bam, no more memory wire.
The obvious problem is one little mistake and you might take out your cable too.
edit: I just remembered I got some IEMs with 2 pin cables from AliExpress. Those will be like $20 a piece to buy on their own, but you wouldn't get them for like a month. Also, of the two 2-pin cables I got, only one fit the ASG 2.5, the other was too wide at the base where the pins protruded and it would not go in all the way. so YMMV if you go the AliExpress route.
Thanks, exactly what I was looking for. Needed a thin cable for the portion that connects into the IEM as I wear glasses. Which incidentally serves as an anchor to keep the cable in place.
You should'nt have an issue with lack of support from the extremely light Linum cables then. go wild! and if the linums work for you, maybe try cutting off the heatshrink the stock cable when you're in a patient mood.
