tomscy2000
I love my FiiO HS2 4-way switchbox, no longer produced.
According to one of the Headfonia guys (either Lieven or Mike), FiiO is releasing something similar, but it seems that there will be less functionality.
Has anyone had any peculiar reliability issues with their Conceros? Mine (HD) just got back from being serviced a month ago or so, and it's already acting up again. I feel like I haven't really read of much trouble with these, wondering if I just ended up with a cursed unit. I would question the quality of my power (hub) or something, but the units seem to be designed to make up for USB power issues pretty well, so...
Could you specify acting up?
Did you try to disable Onboard Sound in bios?
Maybe some other sound device is interfering.
Hmm, okay definitely sounds like a malfunctioning device when it happens on multiple machines.
Sorry to hear that.
I am sure you have checked this, but make sure that the volume on the software you using is not turned off. Try different softwares
I suppose you talk about the Decware Zen Taboo?
Do you happen to know if they have a budget Tube amp (300$ - 500$) which would drive the Hifiman He-500 in an appropriate manner?
