debitsohn
youre not "wasting" much money in any case. especially if you use the FS forum. used equipment in good condition holds its value well.
I would skip the Yulong D100 and go with the Zero DAC/amp as they both use op-amps and thus will sound practically identical if you match op-amps. The Zero can be had for around $100 stock, $120+ with upgraded op-amps and THIS is in my opinion the best DAC to get until you can afford to loose those op-amps and buy something other than Chinese rubbish.
I have got to hear with my own ears that the Zero DAC with an opamp upgrade sounds as good as the Yulong D100. Did he just say the D100 is "Chinese rubbish"? Oh my. The D100 has an excellent amp built in. Does the Zero DAC drive just as well?
I've started looking a bit at the Denon D2000. I've read some reviews, and so far it looks pretty good. The good thing with these puppies are, these are the only ones I can actually hear in real life, as a near-by store sells them. I'm not sure if I have the time tomorrow, but if I do, I might have to go audition them!
Anyone have any good amp/dac suggestions for the Denon?
