ScaryFatKidGT
- Sep 16, 2011
K here is what I got
Shure SRH-840 - little grainy and forward (shouty?) in the mids but other wise great (how I like) in the mids and treble, but no lowend.
DT-770 Pro 80ohm - Use to like them but there really muffled and laid back kind of, not like Sennheiser, they have good speed but they sound like your listening to something far away. Yes there V or U shaped but they also don't have as much high end and cymbal detail as my Shure or Denons. I got them for being bass heavy but the Denons are better. The only thing that they excel at is blocking out side noise, so I use them on the go and when playing drums.
Klipsch Image ONE - less detail and lessor over all headphone but if it wasn't for the boomy heavy sounding midbass (or all bass in general) I would love them. I like bass heavy with a lot of impact but there is like a constant hum or rumble from the bass in these.
Denon AH-D5000 -These sound as close to my studio monitors as I have heard, maybe even more detail. There just a smige shouty in the upper mid's like vocals but are usually nice and smooth and I would like more base if it could tighten up a little. Yes I want more bass then the D-5000's have but that's because its lose, if It was tighter it would seem like there was less bass and a little more would be better but EQ might be able to solve that, I miss my Sony clear bass, my Fiio E17 makes stuff muddy and increases to much mid and upper bass pass 4-6 (the 6, 8 and 10 setting) and ends up making things sound like the Image ONE's.
The reason I want more suggestions is I want something open and also something portable and closed, I just want to try a pair of open cans and my D-5000's don't block out any noise and aren't very secure on my head so there really only for home use.
Thinking about Vmoda-M80's or possibly the M-100's, Sennheiser HD-25-II or Amperior, Denon AH-D600's, Pioneer HDJ-2000's or anything you guys suggest.
