imz14u2nv
- Jul 15, 2005
Hello,
I currently use the RSA Hornet with the Ultimate Ears UE-11 and was thinking of getting the JH Audio JH16 or the UE-18 and possibly upgrading the amp if there has been any breakthroughs in portable amps that can offer me something that would be considered better than what I currently own. I am very happy with my current equipment, but was thinking if I upgrade I would like to do a total upgrade at once.
I sent the following to Ray Samuels but did not receive a response, Ray Samuels has so many portable amps listed I just wanted a kind of brief breakdown on what the difference are and why he makes so many.
Original email to Ray:
Hello Ray,
I am the owner of one of your portable amps (I have the Hornet).
I was poking around on your website today and noticed that you have a ton of portable amps listed there and I was trying to figure out the difference between the various products listed:
•THE SHADOW
•SR-71
•The Tomahawk
•The Hornet
•The Predator
•SR-71A
•P-51 Mustang
Do you have a chart or something that can give me a rundown/comparison of your portable amps?
I currently use the Hornet with the Ultimate Ears UE-11 and was thinking of getting the JH Audio JH16 and possibly upgrading the amp if there was something that you considered better than what I currently own.
Hello Ray,
•THE SHADOW
•SR-71
•The Tomahawk
•The Hornet
•The Predator
•SR-71A
•P-51 Mustang
