Radsone EarStudio ES100
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
284 285 286 287 288 289 290 291 292 293
295 296 297 298 299 300 301 302 303 304
  1. rkw
    Every time you order something from Amazon, you should receive an immediate e-mail confirmation. Verify that your Amazon account has the correct e-mail and check your spam folder. If you log in to your account, the item should be listed in your orders and show status: https://www.amazon.com/gp/your-account/order-history/
    If you can't find any record of the order, contact Amazon: https://www.amazon.com/gp/help/customer/contact-us/
    zeppu08 likes this.
  2. manukmanohar
    You're right. But, i stay in India, and sending it back for repair and then getting it back would prove a long and cumbersome process. Having sold my Q5, the ES100 is the only source i have for my IEMs. I'm awaiting Hiby W5 , so that i can at least send them back through friends. (sending it directly via shipping would be quite expensive, unfortunately, especially with the return shipping, I'll most likely have to pay customs, which would mean buying a new one is cheaper overall)
  3. zeppu08
    Thanks will try to contact them.
  4. mr.karmalicious
    [​IMG]
    still wish this had USB C, but it's a lovely little device :). listening now in 24-bit mode out of my macbook!
  5. Cevisi
    Hi i have a question
    I got the sxfi amp whit ak4377
    Will the es 100 whit dual 4375 be a upgrade in sound quality or downgrade i mean there are 2 chips and the sxfi got ony 1 but a better one
    I will pair my phone and dm6
    Thanks
  6. keoki
    whats a good length to get a short mmcx cable to use with the ES100? Is 2.5' (76.2cm) too long?
  7. Pricklyears101
    This is what 40cm looks like for your reference. Goes beyond the breast pocket. 20190416_072531.jpg
    Abit of dangling wires when clipped on the collar but still manageable.
    keoki and Broquen like this.
  8. keoki
    Thank you for the image, I'm thinking now that 76.5 cm might be too long (I am having a custom wire being build). If you had a choice, how long would you make it (I understand that it's a personal preference).
  9. Ocelitgol
    40cm is fine if you run it around to the back of your neck :)
    30cm-35cm is better if wearing in the front and clipping onto the shirt, I think....
    Really depends on where you keep ES100. I do phone call a lot so it's on my necklace :)
    Also, you can use velcro to shorten the long wire. It may come in handy when ran out of battery and need long wire until you can charge it?
    keoki likes this.
  10. Pricklyears101
    I wouldn't put a definite number to account for the varying heights of different people. For me, as long as i can store the module in my pocket, or clip it on my pocket or collar and still allow for head movements without the wires snagging then I'm fine. It's custom made, so you should be anal about specifications. And the wires should be still light enough to be non microphonic when walking/running.
  11. Cevisi
    so you should be anal about specifications. What does that mean be anal did you write wrong under anal i understand hmm you know
  12. Pricklyears101
    May not be of much help here as i dont have the sxfi but number of dac chips doesn't necessarily equate to better sq in my honest opinion. Dual dacs however does allow for balanced output which, with the right implementation, does put out better numbers than single ended, which may or may not result in an increased perceived sound quality. But then again, there are some dacs or amps which have worse measured balanced output then single ended. I do check out audiosciencereview site for objective tests out of curiosity.
    Bluetooth aac codec input to balanced output vs
    Wired usb to single ended output... I guess you can call it a draw? But you have the samsung though. That pairs better with es100 thru LDAC vs AAC if you have alot of hi res songs, but if it's just mp3, AAC is sufficient enough. I guess it all comes down to their extra features that you're looking for, sxfi earmapping for holographic effect vs es100 eq n taking phone calls. I'd love to lend you mine but due to geographic reasons, yeah..
    You could also consider the audeze isine cable. It has 2 pin, does eq and takes phone calls, and has better dac/amp vs the iphone dongle. Supposedly improves on the isine out of the box.Might just work with the bgvp. Similarly priced too
  13. Pricklyears101
    Umm.. Make sure you and the cable maker understood each other thoroughly enough to make a cable which is according to your exact specifications?
    Nothing sexual or of an offensive nature in the use of the word here, just for simplifying stuff
  14. ClieOS Contributor
    Shameless plug - I have a short balanced MMCX cable for the ES100 for sale. Link in my sig.
  15. benoe
    Fyi there is a special promotion with 15% discount on ES100 during the easter period. Check the amazon stores.
    manukmanohar likes this.
