Oberst Oswald
- Jul 5, 2008
You will love the Bijou...
How about a CanAmp clone for you?
[Pic]
aaahh.. a bit dirty here.
[Pic]
First tests... Had some weird hum. Fixed that with some capacitors...
[Pic]
[Pic]
[Pic]
Put everything together tidily..and finished.
[Pic]
[Pic]
[Pic]
[Pic]
LFF "felt the FA-003’s had particular synergy with the Heed CanAmp." That's the main reason I built this amp. It's dead silent and sounds amazing. Better than the internal amp of Yulong D-100.
I read this whole thread in a month..
Never put this up here, thought some people might be interested in seeing it. It's a cable tester, I can test from (male XLR, female XLR, 1/4" TRS, RCA) to (male XLR, female XLR, 1/4" TRS, RCA). Push a button, if the corresponding LED lights up, you're good, if not then it's miss wired or open. Runs off of one 9V, and I've used it to test cables through walls at lengths well over 500 feet. At some point I'm going to add a ground post to it that I can run a lead from to a piece of conduit or ground point to see if a cable has had it's jacket burned off and is making contact somewhere it shouldn't, but, well, future projects....
Amazing work by everybody here.. Few questions. 1. About how long would you say it takes to complete these projects on average? 2. Does it all come in a kit, or do you have to buy piece by piece? 3. What sort of tools would one need to get into this stuff? Soldering iron, screwdrivers.. what else?
DIY can take a lot of time. Especially if something goes wrong.
I've been working on one project since last September, and I have easily spent 80-100 hours of work on the project. That may be a bit of an extreme example, but it can and will happen.
The very basic tools are soldering iron, soldering wire, a desoldering tool (copper braid and/or pump), a multimeter, and a solvent to clean up the boards (IPA).
But you can find purpose for an almost infinite variety of pliers and tweezers. Different wire clippers too.
If you're doing casework and/or painting you will also need a lot of tools for that.
In my first project I spent far more money on the tools than on the actual parts.
