Navyblue
- Apr 2, 2008
I got the case from a local store, it has no brand. The front panel is rather sharp in the edges.
Thank you for the kind words
, but I am not sure if I deserve that.
On the top panel, the 3 big ventilation holes are off by 2 cm to the right due to calculation mistake. The 2 rows of smaller ventilation holes are also could use more smoothing, I but I am lazy.
On the front panel, the volume pot is oriented wrongly, if I match the D shaft with the knob's tightening screw, it would start at an odd position.
I ignored the D shaft orientation to solve that problem. The headphone jack should also be positioned close to the edge of the front panel. It is positioned at the dead center of the front panel, which is the weakest part, when the jack is pulled the front panel would flex.
For the back panel, it turns out to be better than I expected. But I carved the holes upside down, so I have to install the panel upside down. The consequence is that only 2 of the 4 screw holes at the sides are aligned.
So all in all looks fairly decent in picture, less so when examined closely. But when placed in the dim rack none of the flaws are visible (as you can see in the last picture), which I guess is enough to not bother me.
Very nice casework. What case is it?
