Post pics of your builds....
Sep 3, 2010 at 2:02 AM Post #7,231 of 9,811
@Spacehead: May I ask where you got the plastic case from? It looks very much like the Voyager's case.
Sep 4, 2010 at 4:53 AM Post #7,234 of 9,811
Not so much a build as it is a mod.
A local member here had me repair (stuff 'sploded) and mod his Melos Gold.
The mods:
-> Replace the photenti-crap-ometer with a DACT ct2 stepped attenuator and a ct3 source selector.
-> Replace the crappy loose rca jacks with good quality Connex "WBT Style" teflon isolated jacks.
-> Isolated the board and added a proper ground-loop breaker.
-> Replaced the input caps with Mundorf Silver-in-oil and wired them directly to where they need to be on the board (vs a random walk like the left channel does).
-> Replaced the inter-stage and to-ground caps with Jantzen Superior-Z's.
-> Replaced the final cap after the regulator section on the HV supply with a 100uf Solen.
-> Replaced the HV and LV bridge rectifiers with FREDs.
-> Did the left channel mod (reroutes the left channel interstage path over the top of the board instead of paralleling the HV power line).
-> Rewired the whole thing with Cryoparts TWCu and Neotech Teflon solid cored copper (for people who care about these things hehe).
Before:
After:
Back:
Side:
Left Channel Mode (well the part you can see from the top):
New FREDs:
Input Caps:
Ground loop breaker:
Sep 4, 2010 at 5:16 AM Post #7,236 of 9,811
Cheeky SOB!
John just found the t2 amp board stuffed full of prp muhahahaha   =D
Sep 4, 2010 at 7:45 AM Post #7,238 of 9,811
mundorf brand grain silos
Sep 4, 2010 at 11:00 AM Post #7,240 of 9,811
Something similar here, changed all the caps and installed both bias supplies in a Stax SRM-Xs.  This was originally a electret only amp so no bias supply but the spots were on the PCB so it was easy to fix.
Just imagine how small this could be made today (this was produced in 1990).  Fully DC coupled, fully discrete and capable of being run fully balanced.  This one has mosfet outputs as well...
Sep 4, 2010 at 5:16 PM Post #7,241 of 9,811
The mods:
(photos removed)
Why take out the balanced preamp outputs? that was a very cool feature of the SHA-gold.
Sep 4, 2010 at 8:58 PM Post #7,242 of 9,811
We'll put them back in when we change out the out put caps for that section to match the rest  :wink:
He has no immediate need for them atm.
Sep 6, 2010 at 11:42 AM Post #7,243 of 9,811
Bottlehead Crack
Sep 7, 2010 at 10:46 PM Post #7,245 of 9,811
Not sure if this qualifies, but, it was fun to build from spare parts (except for the box and resistor).
AMB MOSFET Tester/Matcher in-a-box:
Does this qualify as point-to-point?
In action:
Works great! Now to build something real with the MOSFETS!
