It's not something that one would want to stack with SP2000 visually, but I just wanted to mention Korg HA-S. It's a great little tube amp that doesn't get mentioned on this forum. HA-S uses same Nutube as iBasso AMP13 and Cayin C9 (which has two of them). While it's sold as DIY kit, I'm bad at DIY and it took me under 30 mins of simple assembly to put it together, no soldering required. HA-S features a swappable op amp section and comes with high quality MUSES01 op amp in the box.
Portable Tube Amp Recommendations
- Thread starter Dragon Leader
Barndoor
Looks nice, but how practical is it running on 2 x AAA batteries? Do you have to unscrew the lid/case to replace them?It's not something that one would want to stack with SP2000 visually, but I just wanted to mention Korg HA-S. It's a great little tube amp that doesn't get mentioned on this forum. HA-S uses same Nutube as iBasso AMP13 and Cayin C9 (which has two of them). While it's sold as DIY kit, I'm bad at DIY and it took me under 30 mins of simple assembly to put it together, no soldering required. HA-S features a swappable op amp section and comes with high quality MUSES01 op amp in the box.
It is practical, it uses two AA batteries which last about 10 hours. Can use AA rechargeable batteries with it as well. Lid can be unscrewed quickly with fingers to replace batteries, no screwdriver required.Looks nice, but how practical is it running on 2 x AAA batteries? Do you have to unscrew the lid/case to replace them?
sugarsound
I would recommend the Woo Audio WA8. Affordable and one of the best around.
RONJA MESCO
this is the only solution for the quality you get vs the price...I owned this bad boy and had it on my old Sony WM1A and it was excellent.Give Oriolus BA300s a try!
maceto
- Jul 4, 2009
Can Woo Audio WA8 be plugged in while running and if so protected against overcharging?
arftech
- Dec 3, 2010
Yes, the WA8 can be plugged while using it. That’s the way I run my SP3000 and WA8. Magical with Utopias.Can Woo Audio WA8 be plugged in while running and if so protected against overcharging?
pattont
It can be plugged in while using it according to the manual. Also, the battery is user replaceable, but doesn't say it has Mojo2 like desktop mode where it protects the battery to make it last longer if it's just sitting on your desk plugged in.Can Woo Audio WA8 be plugged in while running and if so protected against overcharging?
WA8_Eclipse_Owners_Manual
The Eclipse operates via external DC power or "off-the-grid" battery operation. Advanced technology provides steady and pristine power to the vacuum tubes and the DAC, offering several hours of play – and the unit is operable during charging.
Battery is factory replaceable. Battery should hold charge for many years under normal use.
maceto
- Jul 4, 2009
I am going to get oneIt can be plugged in while using it according to the manual. Also, the battery is user replaceable, but doesn't say it has Mojo2 like desktop mode where it protects the battery to make it last longer if it's just sitting on your desk plugged in.
pattont
Yea, it's tempting for sure!I am going to get one
Loftprojection
- May 26, 2005
I just bought a WA8, received it Monday and I am extremely satisfied. It rivals positively two of my desktop tube amps. The built in ESS DAC is very very good but unfortunately I'm not sold on ESS sound signature so it will definitely not be able to replace the sound of my desktop MHDT Orchid DAC. The amp section is a marvel, definitely does not get all the talk it should considering it's incredible performance while being transportable.
pattont
Congrats!! I messaged Woo Audio to see if I could put a deposit down on one to demo and pay shipping both ways and they said they just weren't doing that which I totally get. I just can't in good conscience buy one from a retailer (they suggested this) knowing I am going to return it because 1. I love it and then I wanna buy one used for $12-1400 or 2. I don't love it and I just return because I don't like it. Either way the retailer is forced to discount it and I don't feel right about that and I don't want to pay full retail for one either way. I don't live near a retailer that carries them so even that option is out .I just bought a WA8, received it Monday and I am extremely satisfied. It rivals positively two of my desktop tube amps. The built in ESS DAC is very very good but unfortunately I'm not sold on ESS sound signature so it will definitely not be able to replace the sound of my desktop MHDT Orchid DAC. The amp section is a marvel, definitely does not get all the talk it should considering it's incredible performance while being transportable.
I have never owned a tube amp and the portableness of this really interests me. Not even that I travel that much for work, but I can take it to other places in my house or go easily sit on my back deck with a whiskey.
Can't wait to one day hear this thing!
