Fiio X7, Fiio Balanced cable and Campfire Audio Novas.... Awesome combo!
- Thread starter RingingEars
jmills8
Previously known as bmiamihk, jmills2
Phone is thinner so stack is thinner.Personally, I've had the Mojo since its launch, and was using it at first with my phone. I quickly realized that it was really impractical because the sizes didn't match at all for stacking plus I had to turn on airplane mode or else there would be too much EMI, which meant I couldn't use my phone anymore... So I pretty much gave up on using the Mojo, almost sold it in fact!
I got the AK70 to pair with Mojo for 3 reasons:
- matching size for stacking
- microSD slot for memory expansion
- the Dignis leather case, which is so much better than a rubber band
Some will argue that using such an expensive DAP purely as a transport is a waste of money, and I agree that any other transport would do. But I'm really happy about this stack because of its size, its practicality, the user interface of the AK, the sound of the Mojo...
So to answer your question, I find it was worth getting with Mojo simply because I wasn't using the Mojo anymore before I got the AK70. But if you are using your Mojo regularly and don't find it impractical and cumbersome, you might as well save your money.
ecva
Here's mine. Similar to ATau's but using bands instead.
AK70 -> Mojo -> Sennheiser IE800
x RELIC x
3M Dual Lock is much cleaner than bands and easy to swap various DAPs.
ecva
Agreed, but for now I do not want to attach something permanent in either the AK or the Mojo.
- Dec 30, 2013
+1 for dual lock. Just bought a roll and couldn't be happier!
It will damage the leather when you peel it off, my Headamp Pico leather case damaged by this 3M tape.
PinkyPowers
Reviewer: The Headphone List
Is it genuine leather?
x RELIC x
I don't care, I have more than one case. :veryevil:
jmills8
Or remove case.I don't care, I have more than one case. :veryevil:
x RELIC x
Or remove case.
Actually I need the case on as I messed up when I sent my measurements to Sysconcept for the optical cable. Without the case the optical cable doesn't line up with the ports. Notice there's no case on the X5ii? A case really doesn't matter, it's really just a user to user preference.
ExpiredLabel
- Nov 1, 2012
If anyone has any idea which would be best? Blu tack or 3m tape? I would prefer it was not a permanent solution, but i won't shrug uncertainty either.
Thanks for the replies
jmills8
velcro comes off easily.If anyone has any idea which would be best? Blu tack or 3m tape? I would prefer it was not a permanent solution, but i won't shrug uncertainty either.
Mimouille
The 3M dual lock is impossible to come off by accident...it is not like velcro but much stronger...it clicks in in a way.velcro comes off easily.
