Originally Posted by
salla45 /img/forum/go_quote.gif
Thanks for reply. I have dabbled with the line out as a direct feed into the IEMs using the Fiio in DAC mode and attenuating volume via the PC. I am told this is unhealthy for the Fiio however as it's not intended to supply current (even in small amounts to the GR10's). Having said that, it does not seem to be suffering. I'd like to hear more on how, specifically I am putting the hardware at risk if sonically I can't hear distortions and nothing seems to be "frying" (ignorance may well be bliss in this case
Specifically in reply to this;
"how did you decide that the line out of the X3² sounded how you wished if the E12 didn't do it? that's probably the most important part to answer you. what conditions gave you a nice sound?"
I'm not sure what you mean here. Perhaps I have replied above to this? The sound is very similar however to that which I get with my Sony Vaio pro 13 laptop (ie the Line out of the Fiio), and that is designed for headphone use.
It's just generally a clearer, cleaner sound, with more "air" and detail to the mid and upper frequencies. I REALLY want to achieve this cleaner sound portably, and it's putting me off listening to the setup I have.
It may be an impedance thin as reviewers have specifically said they can't hear differences in the various outputs and with and without amps, etc. I'm mightily confused and have been considering recently changing players, upgrading IEM's and now looking at further amplification.
You mention this "I suggest EQ(I might be able to help with the values if it's really an impedance thing)" ; you mean using the Fiio EQ? Something Ive been messing with, but I can't get the feeling it's not just levels but detail I'm losing out on and ref this "or buying a resistor adapter"; I have no idea what this means? Perhaps you can elaborate , thanks!
Ps... i was also looking into a simple volume pot to attenuate the lineout level passively whilst on the go, but I think this is a "bad idea" based on what I have said in the 1st para?
Pfff. mightily confused!
Any further pointers are appreciated
