OPPO HA-2 Portable Headphone Amplifier/DAC Discussion Thread
post-13740049
Post #4,561 of 4,818
TjPhysicist
Toronto, Ontario, Canada
It's an option. I did not select anything that's why it is in my notification bar. Zoom in on the
Yes, the selection is to charge HA-2. However, look at the lights on HA-2. Nothing because it is not charging.
Why? The cable that OPPO included does not charge. They disabled some pins or something. You can read up. I just added an OTG USB C adapter to use that cable on my V20 and Note8.
https://imgur.com/a/7gQ2R
:frowning2:. I'm tried the same thing by using their cable with an anker adapter. My phone doesn't even recognise that anything at all is connected.
post-13740082
Post #4,562 of 4,818
djmakemynight
post-13741155
Post #4,563 of 4,818
alpovs
Canada
Canada
can someone suggest a non apple transport for this dac/amp and please also tell me the exact cable you are using. I now have 12 different cables at home NONE of which work. What do you people even use? literally everything i've tried ends up with the HA2 draining the battery of whatever device is connected, most of the time it pLAYS but the connected device dies in 3 hours and i'm left with a useless HA2 with a full battery.
P.S: i will pay $50 to anyone who, before Sep 30th get's me a way to plug my nexus/pixel/LGG6 phone into this DAC without draining the phone. Tell me which cable to buy, make a cable and sell it, IDC, i'll pay you $50 extra if I have said cable inside the week.
Get this cable from eBay: http://www.ebay.com/itm/292052970340
I have it and use with the Nexus 5X. No charging/draining. It doesn't matter what the pull down menu says. Just plug it in and it works.
See my post for reasons why most adapters and cables don't work, i.e., drain phone battery: https://www.head-fi.org/threads/opp...scussion-thread.755879/page-304#post-13739760
Besides, adapter + cable is a hassle - it sticks out too far, slowly ruining the port.
Reactions: Chris Ihao
post-13741172
Post #4,564 of 4,818
TjPhysicist
yea i bought that, a bit short for my liking, but better than nothing i suppose. Unfortunately, this is prbly only gonna be here sometime early november.
P.S: i saw ur post. so IN THEORY. shouldn't "micro USB OTG Cable" -> "USB A Male/Male" -> "usb C "otg" cable" work? Micro usb otg and usb c otg (i.e .both ending in female USB A) are really easy to find, even those properly specced (with the right pins etc as you mentioned).
post-13743934
Post #4,565 of 4,818
djmakemynight
Yeah, I agree that adapter is not the best solution but it is an effective short term fix until the proper cable arrives.
Just wanted to help any fellow HA-2 user(s) who is still looking for cables or bought a ton of cables that don't work.
I have ordered the cable you suggested. Will update when it arrives and tested out. Stay tuned.
:smile_phones:
post-13744356
Post #4,566 of 4,818
TjPhysicist
:smile_phones:
So I just randomly tried the following stupidity: usb micro b OTG (you know the usual micro B to usb A female one), bought a USB A/A Male to Male adapter (i'm not even sure WHY these exist TBH, lol) and then a USB C to usb A "otg" adapter (so the thing is, the moment a proper one is connected to my phone, even before anything is connected to the adapter the phone has that "what do you want me to do with connected device" notification). OTG adapters pictured here: https://source.android.com/devices/audio/usb
And it works (more or less) it's sometimes gets disconnected but the phone now lasts the normal amount of time, so no battery drain. but this does work, in the end. Am still waiting on the 12 or so wires I ordered, I'll post here about exactly which ones work.
P.S: it occured to me, after reading the source.android.com page, that android, for some reason can't do 96/24 natively, :frowning2:. that's rather unfortunate. There are some apps that can, AND for anyone that cares the latest Alpha of poweramp has that ability (only 16 bit though), I cannot clarify it WORKS (i.e. clarify that the signal being received by the DAC/Amp is in fact 192khz but my phone thinks it is).
Reactions: alpovs
post-13744380
Post #4,567 of 4,818
alpovs
Canada
Canada
LOL! I went through this before I figured out what and how it works as I posted above. Now I have multiple short cables and weird adapters lying around.
There is a limitation in Android that it will always upsample and output the highest bitrate the connected DAC claims to be able to accept. If you want bitperfect get this player: https://play.google.com/store/apps/details?id=com.extreamsd.usbaudioplayerpro&hl=en
It's expensive ($10) but worth it. It uses its own driver to output bitperfect but it works only from withing the app. But it has integrated TIDAL, which I like.
post-13744392
Post #4,568 of 4,818
alpovs
Canada
Canada
If you go the adapter route make sure get the adapters with 5.1 kOhm resistors. The problem is that often it is not mentioned in the description or what is mentioned is wrong.
post-13755095
Post #4,569 of 4,818
DrunkSaru
San Fernando Valley, CA
Bought a cable from ebay it costs 7 usd, if you look for usb cable oppo you will find it. Took a month to get it but its not charging the oppo anymore :)
Look for yourcharger seller he has a few variations of the cable
Thanks Swesko. I got my cable last night, plugged it in and yeah, reverse charge not happening. This is great. Now I have to figure out what I'm going to do with all these other cables (just counted 9 total) that I bought in the beginning that never worked for me. Maybe i'll hold on to it and see how they do when my phone upgrades to Oreo.
Edit: I bought 2 cables just in case. Both worked so it's good. I then started to comparing the cables (old and new) to see any pins were missing or construction was different but everything looked fine. I then noticed that the new cable bent easier than my old cable. FYI: these cables look identical. So out of curiosity, I decided to splice one of the new ones. It's missing one wire - the wire that would send power. This explains why this cable (the new one) won't charge other products and doesn't have the issue of reverse charging with the HA-2. Also explains why when you plug cable into the phone, Android still thinks something is connected and that menu pops up saying it's charging the external device. I thought after reading responses from many and many claimed it's not the OS, my fallback hypothesis was controller chip on the USB. I'm now back to thinking it's still an OS issue. I don't recall a massive battery drain when my phone was running Marshmallow but then again, it wasn't until Nougat that the feature of charging an external device came into play. At least I have a working cable now and also have a slightly longer one on the way too.
post-13756247
Post #4,570 of 4,818
spw1880
Indonesia
Indonesia
Age
39
Hi all oppo users,
I would to ask if anyone knows if the oppo ha2SE has the same seperate grounds design on its headphone out as the first gen oppo ha2. So as to be able to accept TRRS balanced connection.
Btw i have some short cables from penon audio, moon and lavricables and have all worked well hope that helps somehow. They are obviously more expensive the the average cable. (Durability goes to penon and moon) But have had no issues with connection or charging with my phones. I have no comments on sound diferences..i just focus on ergonomics, durability which i know using larger gauge good quality copper will affect, along with proper shielding and casing on the connectors matter also. I have used some other short cables in the past and many have not stood the test of time through rigours continuous use on the go.
Cheers
post-13760905
Post #4,571 of 4,818
Ash Hayes
UK
UK
Looking my for a way to attach this to an iPhone 8 Plus. Someone recommended using an iPhone JimmyCase which looks like a good idea. Any other decent recommendations?
Cheers.
post-13761709
Post #4,572 of 4,818
Cuenca John
Cuenca, ec
Cuenca, ec
Cheers.
Well, for a temp use, you do have the two silicon bands supplied by Oppo, that will hold the dac to the iPhone.
For awhile, I used them to strap the dac to my iPad mini.
post-13767597
Post #4,573 of 4,818
Zodler
I just got HA-2SE. It would have been great if you could see on the DAC the sample rate it is playing.
post-13777287
Post #4,575 of 4,818
jhog
Sweden
Sweden
Anyone tried this with the fiio x3ii. Is it a decent step up in sq?
Thanks in advance!
