Briefly, and I mean briefly at a meet with a recabled (balanced) dt990 600ohm. It was a pretty amazing closer for the last two minutes of the meet. Sorry, I can't really be any more help.
Sorry if this is old news but I remember reading some time ago about there being some firmware updates for the Oppo HA-1. Is there a big difference between the firmwares? Do they change the sound? Or does it even matter?
No the firmware only fixed little insignificant things like a misspelling on the screen. It did not affect sound quality and I don't think they even offered a way to upgrade the firmware anyway
This might be a really dumb question but could I have 2 headphones plugged into this at the same time, one using balanced XLR and the other using standard single ended, and then switch between them whenever I want?
From my experience, plugging in the single ended plug mutes the balanced cable output, so, you do have to manually uplug the single ended to switch.
What i do, that probably wouldn't apply to most is: I have my pm-1 connected to the balanced cable and also have a Senn RS 220 Wireless cans connected to both the rear analog out and also the optical out of the HA-1 into the RS 22O's and that gives me the only seamless switching that I could think of. But to my knowledge, plugging into the single ended output mutes all other outputs. Hope that answers your question.
