Images
| | Wifi 802.11AC, DLNA
Bluetooth AptX
Google apps, Spotify, Tidal, Deezer, etc
MQA Playback (an industry first)
PCM 384khz
DSD 256
Body Color | Smoky Blue
| Stone Silver | Gun Metal | Gun Metal | Black |
Body Material | Aluminum
| Aluminum | Aircraft Grade Duralumin | Aluminum | Machined Aluminium Unibody, Anodized Finish. |
Dimensions | 2.16" [W] x 4.37" [H] x 0.58" [D]
55 mm [W] x 111 mm [H] x 14.9 mm [D]
| 2.16" [W] x 4.64" [H] x 0.58" [D]
55 mm [W] x 118 mm [H] x 14.9 mm [D]
| 2.59" [W] x 4.21" [H] x 0.68" [D]
66 mm [W] x 107 mm [H] x 17.5 mm [D]
| 2.95” [W] x 4.42” [H] x 0.64” [D]
75.15 mm [W] x 112.4 mm [H] x 16.45 mm [D]
| (mm):128.9*75.9*12.7
Weight | 5.99 oz (170 g)
| 6.24 oz (177 g) | 6.5 oz (185 g) | 7.65 oz. (217 g) | 203g |
Output Level | Unbalance 2.0Vrms /
Balance 1.7Vrms
(Condition No Load)
| Unbalance 2.1Vrms /
Balance 2.3Vrms
(Condition No Load) | Unbalance 2.1Vrms /
Balance 2.3Vrms
(Condition No Load) | Unbalance 2.2Vrms /
Balance 2.3Vrms
(Condition No Load) | 150mW+150mW (balanced), 75mW+75mW (single ended). Supports 16Ω--600Ω. |
DAC | Cirrus Logic CS4398 x1
(Single DAC)
| Cirrus Logic CS4398 x2
(Dual DAC) | Cirrus Logic CS4398 x2
(Dual DAC) | AKM AK4490 x 2
(Dual DAC) | 2x ESS Sabre ES9018K2M |
Frequency Response | ±0.025dB
(Condition: 20Hz~20kHz)
Unbalanced & Balanced
/ ±0.6dB
(Condition: 10Hz~70kHz)
| ±0.023dB
/ ±0.3dB
| ±0.023dB (Condition: 20Hz~20kHz)
/ ±0.3dB (Condition: 10Hz~70kHz)
| ±0.053dB (Condition: 20Hz~20kHz)
/ ±0.56.dB (Condition: 10Hz~70kHz) Unbalanced: / ±0.55.dB (Condition: 10Hz~70kHz) Balanced
| SE No Load
+0.02
- 0.32
Signal to Noise Ratio | 115dB @ 1kHz, Unbalance
/ 115dB @ 1kHz, Balance
| 116dB @ 1kHz, Unbalanced
/ 117dB @ 1kHz, Balanced | 116dB @ 1kHz, Unbalanced
/ 117dB @ 1kHz, Balanced | 120.3 |
Crosstalk | 127dB @ 1kHz, Unbalanced
/ 130dB @ 1kHz, Balanced
| 130dB @ 1kHz, Unbalanced
/ 135dB @ 1kHz, Balanced | 130dB @ 1kHz, Unbalanced
/ 135dB @ 1kHz, Balanced | -120.1 |
THD+N | 0.0009% @ 1kHz, Unbalanced
/ 0.0008% @ 1kHz, Balanced
| 0.0007% @ 1kHz, Unbalanced
/ 0.0005% @ 1kHz, Balanced | 0.0007% @ 1kHz, Unbalanced
/ 0.0005% @ 1kHz, Balanced | 0.0008% @ 1kHz, Unbalanced
/ 0.0007% @ 1kHz, Balanced | 0.035 |
IMD SMPTE | 0.0004% 800Hz 10kHz(4:1) Unbalanced
/ 0.0003% 800Hz 10kHz(4:1) Balanced
| 0.0007% 800Hz 10kHz (4:1) Unbalanced
/ 0.0006% 800Hz 10kHz (4:1) Balanced
| 0.040%
Output Impedance | Balanced out 2.5mm (1ohm)
/ PHONES 3.5mm (2ohm)
/ PHONES 3.5mm (2ohm) | Balanced out 2.5mm (1ohm)
/ PHONES 3.5mm (2ohm) | Balanced out 2.5mm(1ohm)
/ PHONES 3.5mm(2ohm) | 0.5 ohm (single ended), 1 ohm (balanced). |
Clock Jitter | 50ps (Typ)
| 50ps (Typ) | 50ps (Typ) | 30ps(Typ) / Reference Clock Jitter 200 Femto Seconds | |
Memory | Built-in : 64GB [NAND]
/ External : microSD (Max 128GB) x1
| Built-in : 128GB [NAND ]
/ External : microSD (Max 128GB) x1 | Built-in : 256GB [NAND]
/ External : microSD (Max 128GB) x1 | Built-in : 128GB [NAND]
/ External : microSD (Max. 128GB) x1 | 32GB internal storage
Dual Micro SD slots (SDXC) Max 1TB?
