T.R.A.N.C.E.
- Mar 24, 2010
Yes, I'm well aware of the Tera's simplicity, nothing wrong with that. SQ is king IMO. You also forgot about the HM60x DAPs that are also R-2R using the Phillips TDA1543.
Actually I mistakenly said Tera has an R2R dac, that is incorrect, TDA1543 is not an R2R dac either. Tera's dac (Philips unknown), TDA1543 and PCM1704 are all Multi-bit dacs, but Multi-bit dacs come in 3 different architectures, R2R (PCM1704), Current weighted (TDA1543), and Resistor string (DAC8552). R2R design was known as the best of the Multi-bit dacs, people often confuse R2R as meaning any Multi-bit dac, which is not the case in technical terms. But in general terms all the Multi-bit dacs had similar design philosophy, very different to delta-sigma dacs.
