- “Resume” function.
*Re-start from the beginning of last song after Turn off and on.
Loving the DAP BTW.
Turn it off while a song is playing, next time you turn it on you will see the song and album art at the bottom of the screen, tapping that makes the song start from the beginning.
Got to try this tonight (twice). Didn't work. Held down the power button while a song was playing and did a complete shut down. Turned it back on after a couple of minutes and only saw the regular screen (after it syncs the cards). Using firmware version 1.21. Guess I'll just have to live with it unless you know of something else to try.Turn it off while a song is playing, next time you turn it on you will see the song and album art at the bottom of the screen, tapping that makes the song start from the beginning.
Success! Domo arigato!Maybe turn off Auto-synch.
Cool. Yeah, as soon as you mentioned that in the boot-up... thanks for doing that.Success! Domo arigato!
Can anybody recommend a good, reliable high capacity SD card ?
I have over 1000 CDs ripped to 24bit/192khz and change the contents of the Pioneers' cards about once a month. The Samsung/Toshiba cards I have will only take 5 or 6 write cycles before giving up the ghost.
(I don't think they like having files > 100mb although I guess some cameras generate big files these days.)
Out of curiosity why did you rip the CDs to 24bit/192khz? Given the original 16bit/44.1khz does upsampling really pay off with the increased file size?
To answer your original question the Sandusky Ultra have worked very well for me and have been through many write cycles. I also have a fair amount of 24bit/192khz files and haven’t had any issues. The 256 GB cards are pricey.
To answer your original question the Sandisk Ultra have worked very well for me and have been through many write cycles. I also have a fair amount of 24bit/192khz files and haven’t had any issues. The 256 GB cards are pricey.
Not Sandusky, Sandisk...oy, that's a typo for the ages.
Yeah, ripping those to 24/192 is a complete waste, and there is NO way Samsung card will only sustain 5 write cycles, more like 500 to a 1000.
