Thanks for the reply!
Just curious about how to differentiate shielded and unshielded cable ? I have found several high grade cables (like Audio Quest) online that do not specifically stated that they're shielded, does it make a difference?
It's likely that audio quest cables are shielded too, but I have tried a few audio quest cables and specifically had a huge problem with a USB cable from them. I had to return it due to jitter or errors in general that translated to gaps of audio play. I replaced it with a stock cable and it worked fine. When I got new gear I tried Pangea USB cables as they came highly recommended to me. They are very high quality for the money and if you compare specs between them and the best of USB cables, you will see how good of a deal they are. Pcocc silver plated 4% wire, shielded, high quality braided sleeve.
Basically recommending them as a high quality cable. I personally don't believe a lot of the hype behind digital cables being measurable differences in audible audio for the most part. Use a quality cable and be done with it. Keep the cost reasonable!
Thanks! So you suggested that the Draug would generally be warmer/darker sounding than the sliver Solv X? Definitely will consider that.
