arijitroy2
- Jun 29, 2015
I have cable rolled with mine but to me I never want any cable to CHANGE the sound. Too many cables these days mess with the sound too much.
The Sultan is a very revealing beast. I am presently pairing mine with the Noble Vivid Cable, which does not really affects the balance and the sound signature, the sound remains clean and smooth with realistic details and believable timbre and body, but the sound is given a fair bit more air and space with the Vivid Cable, and that's all I want it to be. I have tried the Halley and despite the difference in cable materials and geometry it does sound like a mini-Vivid, just a hair less of that air and space while doing everything else pretty much as well. Do not expect the sound to be brighter with the Halley (common perception (and a wrong one I gotta say) that silver sounds brighter than copper), brightness and warmth are fairly similar between these two. Both cables are nicely made and aesthetically pleasing - it's amazing how the 16-wires Vivid could be so supple and manageable while keeping a fairly silent background with only visually thin insulation (of cos can't tell for sure what kind of and how much insulation is there).
My 2 all-time favourite general purpose cables are the Crystal Dream Duet (silver) and the Brise Audio Yatono Limited (copper), both basically matches with every iem I throw at them, and in fact both sound great with the sultan as well BUT these 2 are truly pristinely sterile sounding cables with pitch black backgrounds, and with the vast detailing in the Sultan the end results sound a tiny bit too brutally revealing (i.e. bit tiring) for enjoyment purposes.
If you are gonna get the Sultan I really recommend at least trying them out with the 2 Noble cables. I'm also happy with the pairing with Plussound tri-silver but I kept coming back to the Vivid for its tiny bit smoother sound with the Sultan and eventually settled on that combo.
Thanks for this, helps quite a bit in narrowing down the cable choices. Even Bloom Audio recommended the Vivid Cable for Sultan, I might look into that one, it does add up the cost quite a bit, but I can invest if it really brings a difference to the overall experience!
My eyes were on Eletech's Socrates, a new cable but I will wait for @mvvRAZ on his opinion on that combo.
