Eddie le
Hi guys, will Khans have a next generation? Thank you!
I’ve heard rumors of a full metal Khan but can’t confirmHi guys, will Khans have a next generation? Thank you!
This is a cursory comparison between the 2 (I haven't had a lot of listening time with the Tux 5, thus far).Can anyone compare Tux 5 vs Encore?
Interesting. I'm not a fan of hot treble, and I've heard all 3 (major) versions of the K10 - the original, acrylic one, the aluminum version and a custom form, which I own. All 3 of them have a treble response that is sparkling but controlled. I'm not doubting what you hear, but I'm just surprised that you'd find them a little too harsh/sharp for your ears. I really hope that you can tame the treble; foam tips usually help in this regard.From what I know there are differences between k10 and k10ua cuz of the different housing materials. I have very deep fit with mine and its def a brighter sound sig with a hot treble. I use symbio tips with abit more narrow bores to bring the treble down abit. I find if u use wide bore silicone tips they tend to reduce bass and boost the treble. Comply tips basically kills the treble all together. I been looking for a way to tame them abit with cables or tips without losing the resolution.
Would you describe M3 sound-stage as open, ambient or it's just air and separation without good positioning? Is it deep and/or broad?Smoothed out, ultra open
Thanks to all for the responses, I have decided to get Khan, I hope it suits my taste better.
I would say the Khan is the product in Noble's stable with the cleanest, most transparent sound. Unfortunately, it was a little too lean for my tastes. The treble was also a tad too hot. In any case, for anyone seeking that particular sound signature, the Khan is definitely one of the must-have IEMs on the market.For what it’s worth, I think Khan is easily Noble’s best IEM. It’s a bit treble heavy, but if the tuning choice works with you, it’s a nice IEM.
People are sensitive to different frequencies. If you give me an IEM with loads of bass I can do more than an hour or soThe only person Ive read that described the k10ua as im hearing it spot on was Twister6. You are right that the treble is sparkly but its also abit splashy and hard edged. Im abit curious how even brighter iem like khan sounds and how people can listen to them for long periods of time without getting serious fatigue.
I am at the opposite side of the spectrum, from my friend @mvvRAZ, and as someone who is super sensitive to high frequencies, I don't find the K10U treble splashy or hard edged at all using my Galaxy S10+ as the source. The treble has a just the right amount of sparkle, and more detail than I have ever heard before, so it took me some time to acclimate to hearing all that detail, but now it is just pure bliss. I have been listening with my K10U paired with my S10+ non stop since I got them, and have yet to get any fatigue. Perhaps a warmer source could help?The only person Ive read that described the k10ua as im hearing it spot on was Twister6. You are right that the treble is sparkly but its also abit splashy and hard edged. Im abit curious how even brighter iem like khan sounds and how people can listen to them for long periods of time without getting serious fatigue.
I found the K10UA quite shrill as well when I first heard it in 2015, but I hadn't been active online then, so those impressions never found their way out. At that point, my friend and I were both debating getting a custom K10 after hearing its acrylic demo unit, particularly enjoying its warm, mellower top-end. Once we tried the K10UA, though, we were surprised by how strong its low-treble was, and it put serious doubt in the both of us, because we didn't know which version the custom would most closely resemble. The question was also brought up at the CIEMs panel at CanJam Singapore 2016, but John stated that given the internals' sealed system (from driver to tube), the change in chassis wouldn't translate sonically. To this day, I haven't given it another go, but I'd love to with different tips, because that could've been the difference maker that we hadn't thought about in our initial tests.
I can safely say, though, that the Khan won't sound harsher or splashier than the K10UA. It's on the brighter and leaner side, yes, but that's mostly because of its laid-back lower-mids, rather than any sharpness in the treble. It certainly doesn't have the hard edges that the K10UA had. So, if you could find one, I'd venture you give it a demo to see if it'll fit your tastes.
