y2jdmbfan
- Feb 2, 2005
Wizard, or anyone, is the Light Smoke option on the custom Encore shells see through at all?
Its translucent unless something has changed, which I doubt.
Awesome, I think I am going to order either some custom Encore's or Katana's. Trying to figure out the color / design. Might go with Light Smoke shells with Carbon Fiber Black / Blue faceplates. Afraid to go totally clear as I don't want them to yellow.
Mojo's are nice, but its issue is the same as using an amp, stacking sucks for portability.
Side note: if Chord added Poly-like functionality to the Hugo2, that would be a worthwhile addition.
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
It’s called the 2go and should be released this year.
Looking for a cable for my Encores
to use with a SP1000 2,5mm
Maybe one for travel as well ( bax maybe )
maybe an adapter for 2,5 to 4,4mm since i can use it with a Sony 1Z
İdeally one Cable only to solve al my problems
Budget around 5-700$
Noble new Cable maybe? İf it comes with 2,5 balanced
Any help is highly appritieted
What improvement do you want to achieve from the cable upgrade? Sonic preference?
