Noble Audio - the Wizard returns!
May 13, 2017 at 9:38 AM Post #25,517 of 36,071
Any cable recommendation for k10ua ?
Thanks in advance :)
I've used a variety of cables with my K10, and its best match is with Toxic Cable's Silver Widow. Brings the treble a little closer to you.
May 13, 2017 at 11:49 AM Post #25,518 of 36,071
Eartips are truly a pain. I have tried just about every type known to man, but settled on (though not in love with) the triple flange tips with 4.5 mm stem hole for my universal encores. Takes time to get used to them tight in your ears, but they are the only ones that consistently give me a decent seal. Also, noticeably cut down on distortion by going deeply closer to the bony part of the ear canal. The customs do this without the discomfort so you might want to consider.
May 13, 2017 at 12:47 PM Post #25,519 of 36,071
me and my pal are facing difficulties keeping the iem in ear securely, despite many types of tips tried, any suggestions for solutions?
Which tips have you tried?
Spinfits, Spiral Dots and generic tri-flanges tend to work well.
Foam based tips should always give a good seal - I'm currently using Inairs with my K10Us
May 13, 2017 at 6:07 PM Post #25,520 of 36,071
Following on from my first reply I received my Toxic Cables Silver Widow V2 today and the flexibility is amazing. It feels so buttery smooth when it moves and it is nice and relaxed when it hangs from your ears.
May 13, 2017 at 11:16 PM Post #25,521 of 36,071
i have tried the ones from final audio, RHA, noble stock single double, they will fit for a while but a little movement and it gets pushed out
i have a pair of snugs in the pipe though, will see what it can bring to the table
May 14, 2017 at 5:31 AM Post #25,522 of 36,071
The snugs should turn them into customs - no more tip issues.
Do they cover all the current Noble line now or did you have to send your IEMs off with the impressions?
May 14, 2017 at 10:08 AM Post #25,523 of 36,071
For anyone interested, here's my take on the Noble X:
https://www.head-fi.org/f/showcase/massdrop-x-noble-x-universal-iem.22025/reviews#review-18582
May 14, 2017 at 10:47 PM Post #25,525 of 36,071
luckily they have base schematic for most iem and can do them, snugs uses 3d scan in ear though, so no silicone injection and much more comfortable to do
May 15, 2017 at 3:45 AM Post #25,528 of 36,071
Are those crocs universal or custom fit!
May 17, 2017 at 12:03 AM Post #25,530 of 36,071
Had my mom listen to the Katana's tonight through my Mojo, her first time using anything better than iphone headphones. She said she almost started crying her favorite song sounded so good :)
