- Dec 1, 2014
im thinking about Ak300 when its released but will it be a good enough source for kaiser 10?
Audio Performance
- Frequency Response
- Signal to Noise Ratio
- Crosstalk
- THD+N
- IMD SMPTE
- Output Impedance
- ±0.075dB (Condition: 20Hz~20kHz) Unbalance & Balance
±0.56dB (Condition: 10Hz~70kHz) Unbalance / ±0.55dB (Condition: 10Hz~70kHz) Balance- 116dB @ 1kHz, Unbalance / 116dB @ 1kHz, Balance
- 130dB @ 1kHz, Unbalance / 130dB @ 1kHz, Balance
- 0.0008% @ 1kHz, Unbalance / 0.0007% @ 1kHz, Balance
- 0.0007% 800Hz 10kHz(4:1) Unbalance / 0.0006% 800Hz 10kHz(4:1) Balance
- Balanced out 2.5mm (1ohm) / PHONES 3.5mm (2ohm)
im guessing balanced is the way to go with it?
The best synergy I've found with my K10s in a DAP (better than even the AK240 and AK380) is the AK100ii, which the AK300 appears to be replacing in the AK lineup, so I see absolutely no reason why the AK300+K10 couldn't be a great source+iem matchup. You'll just have to test and decide (hint: purchase from a store or website with a great return policy and no restocking fees).
