NEW XDUOO X serie DAP-X20, X10+ & X3+. XDUOO Are on FIRE!!!
- Thread starter NymPHONOmaniac
kundatra
Does anyone (thanks a lot, XVortex)) know what is a difference between rockbox 4447a3e-190819 for xDuoo X3ii based on stock 1.20 and f9ff417-190204 also based on stock 1.20?
XVortex
- Jan 19, 2016
There are about 200 commits from February to August 2019: https://github.com/Rockbox/rockbox/commits/master
flamesofarctica
- Nov 5, 2016
Ok I'm a bit late to the X20 party, but I'm loving the sound quality of this DAP. Less warm than my other main players, so a nice contrast as it brings out a lot of details, and manages to do that without any harshness. I'm impressed.
Pewterlocks
Will the x20 push full sized headphones?
hakuzen
- Feb 9, 2016
in balanced output it manages to drive HiFiMAN Ananda and HE400i here, so go figure. high gain, volume 65-85/100Will the x20 push full sized headphones?
flamesofarctica
- Nov 5, 2016
Mostly I've used with on ears (Koss, Grado) and earbuds, but have tried with some full sized (my JVC's for example) and no issue driving them to sound great
funkymartyn
Does anybody know if and what sort of prices the xduoo audio would cost from Japan . As got a friend going over there from the uk soon.. And wouldn't mind a decent priced xduoo.. Thanks.
counterclockwise
xduoo doesn't actually seem to have much of a presence here. even the big go-to audio gear stores i've used (e-earphone and soundhouse) list only a few and no xduoo items, respectively.Does anybody know if and what sort of prices the xduoo audio would cost from Japan . As got a friend going over there from the uk soon.. And wouldn't mind a decent priced xduoo.. Thanks.
won't rule out that you might get lucky and stumble upon a nice deal somewhere, but generally speaking i find that the cheapest way to obtain xduoo products here is to just order them from aliexpress. ¯\_(ツ)_/¯
Hello folks.
I have the X20, but I find it a bit cold. I wanted more low end and warmth ...
Recently I received the Ibasso DC01 wich is very good to my taste.
Turns out that I pluged the CD01 on the USB C of the X20 and it was recognized and works playing music ! I imediately was excited to try the combination. But looks like that the X20 is set to only output through usb-c at maximun volune. The X20 volume control just does not work, and the level is ear bleeding.
So, someone have any idea of how it could be solved ? Or is it impossible ?
hakuzen
- Feb 9, 2016
try settings "Output mode" (set to LO) and "LO Volume" (set to Activated), in Music SettingsHello folks.
It did not worked.
I only use full-size headphones and find HD580 Jubilee works well for me with the X20 ... also a wired Bose QC35 (with NC on) sometimes, as it's more compact for travel and has the BT option.
fmdlnt
- Oct 24, 2016
I posted this question on a separate thread, but maybe I will have better luck here. What is the difference in sound quality between X10T/X10Tii and X20? I know the sound of the original X3, which I used with Rockbox, and liked it.
Thanks in advance.
@fmdlnt ... I only have experience with the X20, ... so, can't be of any help to you
