cuiter23
Does really 2 times more expensive is better by 2 times? No doubt se846 is better than se215 but it is the overall synergy and value for money. With better cable, any iem will sound better than stock cable. I am just sharing how good and value for money is se215 and with better cable, you will find the potential of se215. Se846 is more than 10 times expensive than se215 but is it 10 times better? With stock cable, Dita Truth and AKi8e is better than se215 but with better cable on se215 will not lose to those iem. Of course, you can say that with better cable on those iem, they will sound better than se215 but by how many times better for the money spend?![]()
I've owned all the SE up to the SE535s. The only one I've kept are the SE215s and got them custom shelled. The shell cost 2x the price of the IEMs. I kept them not because they sound the best (the 535 and 425s are much better sounding units) but because I use them on stage and can throw them around and relatively cheap if they break. They are built like tanks.
Also, there is no way a cable can make the SE215 sound even close to any of the TOTL IEMs. I am part of the minority who believes that cables do make a difference but minor improvements especially in headphones and even less in IEMs. The case with loudspeakers is different as it can definitely alter the tonal balance a lot more.
If you're happy with the 215s then you've just effectively saved yourself a couple thousand bucks from upgrading lol but you are in the small small minority.
