Dobrescu George
Reviewer: AudiophileHeaven
Oh yes, Hidizs is doing a great job in there!
And so do you
Hi, I've been wondering - Fiio says that they have made some software customization to the android sounprocesing core. Does the AP200 have anything like that? Does it even matter? Isn't it just a marketing statment? Thanks
Really wonder if this dap compare to the oppo ha 2 dac,i know both of these product are not really the same thing,just curious about the sound quality.
Thanks for the reply,the oppo and hidizs are not really have much price different in my country,the hidizs dual dac with 24k gold shielding really make sense,both no mention what other component and chipset they have used,the oppo just with a single es9028 q2m DAC chip.FiiO did make some improvements on the Android level, but they dedicated a lot more work to optimize that just for their FiiO app.
Hidizs works with Hiby and it should also have some optimizations, but I don't know if the changes are similar to what FiiO does.
I think that it would be a pretty far fetched comparison between them, if I remember well HA2 is more expensive, and it is a bit of something else.
Sound wise, I had the chance to look into HA2 and I'd say that it is a really nice DAC/AMP, it is a tad brighter in general , with a the signature being a bit lighter overall. I'd need more time to have a more detailed comparison.
Finally done back reading from page 1. I am new to the DAP community and I am leaning more towards this unit but torn whether to get the SS 128gb Carbon Fiber or the Rosewood back plate.
Will you guys Rec'd this unit for an entry level or as a starter kit for a newbie like me? I am on a verge of pre-ordering this unit here in our country in PH and will be able to get it within a week.
@Hawaiibadboy as always great vids. Keep it up sir.
Thanks in advance.
The back design should really depend on your taste, one major advantage for me of a wood back is it wont shatter like tempered glass in case of accidents but wood may absorb water and oils, the decision there is really up to you.
As for recommendation, I don't think this is considered entry level (more like middle,.....
and 64gb for a friend who's helped me a lot when I was in the dumps)
