#1555 reporting in.
As I have been listening to HD800 for several month, most impressions are actually a comparison to HD800. So it could be bias, or not "accurate" (especially on criticisms
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
First impression:
Package: I'm rather disappointed the with content of the package, I was hoping it comes with either a wood box, or a carrying case like other WXXX. Oh well let's move on...
Build: It does look sturdy. But I guess no one will try to throw it down 3 floors and see if this baby survives...
Look: Yes the killer look and yes, photos will not do this beauty its justice. I believe will only get better when the paint dries out with wood pattern starts to show...
Comfort: This phone is extremely light - so light that I had an impression that it's made of paper. It's lighter than AKG701, and HD800. However this doesn't mean it's perfect. The headband. Its design limits the ear cup's flexibility where drivers will not get straight vertical parallel position. Bottom of the skull gets most of the pressure, rather than evenly distributing around the ear. The size skull will determine driver's angle, and will be 'slightly' different for everyone. I hope this will not affect the sound too much. HD800 has a better ergonomic design, and more flexible for adjustment and comfort. W3000ANV touches my ears.
Isolation: If you need isolation, looks elsewhere...
Sound: As many has indicated, this is not the most detail or "high tech" phone, so it does have flaws. But it has it magic...
It's warm, and the treble is tamed - This makes this phone forgiving. Overly bright recordings (like Japanese pressing of Heifetz recordings, for example), or pre 50s records with lots of hiss, W3000AMV is more enjoyable than HD800. Also jazz trumpet is more comfortable to my ears... (I'm not a brass fan btw)
Mid is beautiful and I'm out of words to describe them - go see other posts
Bass however is rather loose, with long decay, W3000ANV sound muffed and lack attack on the low register. The Jazz Messengers Hank's Symphony is far better on HD800...
Don't get me wrong - this is possibly the most beautiful "pre-break-in" sound I have heard, and Audio Technica made a good statement with this beautify piece of artwork.
W3000ANV and HD800 makes a good paring with strong contrast on each other. On look and design, being classy v.s. hightech. On sound, being musical v.s. accurate.
I will let white noise and frequency swap run through this baby several days and see how things change... I hope the bass will tighten like how K702's bass got tighten over break in.
Note: Orchestra work is surprisingly good on W3000ANV too!
p.s.: I like to listen on low volume, however on low volume, the phone sounds totally different, and a bit "distanced". I cant find the right word to describe it. However the problem goes away if I turn up the volume to about -20 dB on mid gain. I have been listening on HD800 below -25 dB on mid and high gain but does not have this problem.
