hifidk
- Feb 19, 2009
Also, I've discovered that the JMoney Beyer pads fit on these guys. ( the ATs not the cats)
How is the comfort with Beyer pads? Any change in sound?
a bugaboo i have with the w3000anv is the fit. mine clamps and while the leather earpads look luxurious, they're not deeply padded. it's always a bit of a relief to take them off to be honest. i've worn more comfortable headphones.
it probably seems unusual because i've read posts from w3000anv owners describing theirs as loose fitting. i've tried other a-t models and they exerted little clamping pressure but these definitely exert more. i have an average sized head and don't wear glasses.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
I'm finding the pads a bit strange on these. The opening seems a fair bit smaller than my other over-ear phones. Whereas the headband seems to have been made for heads on the large size.
The comfort isn't bad. But TBH the Denons are way more comfortable than the W3000ANVs.
I have the same issue, and measured them against my W5000s which for me, after adjusting the bend, are still the most comfortable headphones I own. The W3000 pads have indeed a smaller inside diameter, just enough to be a bit tight around my apparently largish ears... (the depth is the same though)
As far as the clamping goes, they can be fairly easily adjusted by bending the arcs one way or another. The tricky part is that the clamp is uneven from top to bottom... by default they are so angled that while they clamp quite firmly at the bottom of the pads, the top is almost loose. That does not just create a problem with seal (and thus potentially anemic bass) but also longer-term comfort.
The W5000 were not that angled to begin with and fairly easily bendable, but with the W3000, I had to apply significant pressure against the edge of a table to change the angle to something straighter... But thanks to that the fit is now much better (nothing can be done about the pad diameter obviously)
