New FiiO M11S Player with dual ES9038Q2M DACs, 670mW output power and 14 hours of battery life
Dec 27, 2022 at 1:03 PM Post #257 of 641
Hello to all. i am comming from M9 and now upgrade to M11s - the difference is huge in functionallity and sound quality i also notice some difference...its a petty that is so big...nevertheless.... i have some questions, hoje someone can help:
IS UAAP making some difference?
what apps you guys using in fiio in general?
question for FIIO: i can translate all software to portuguese free of charge...can you accept my offer ?
Dec 27, 2022 at 1:08 PM Post #258 of 641
^ are you saying the M9 to M11s sound quality difference is minor?
Dec 28, 2022 at 8:44 AM Post #262 of 641
Dec 28, 2022 at 9:03 PM Post #263 of 641
The new firmware FW1.0.2 for M11S is now available!
The following changes and improvements have been made in the new firmware on M11S:
1. Added ROON Ready function (on desktop screen or click the FiiO Roon in the drop-down menu to use);
2. Added second harmonic regulation function (can be set in the Settings - Audio - Second harmonic regulation);
3. Added experimental functions (PEQ, DLNA transmission);
4. Added support for DTS format;
5. Added desktop icon shortcuts for FiiO Music (multimedia service, local music, playlists, continue);
6. Fix the display error of sampling rate on the status bar when playing music using third-party apps.);
7. Fixed display problem of some MQA tracks;
8. The tracks in the DLNA album directory are changed to be sorted by track numbers;
9. Miscellaneous improvements in performance.
M11S firmware download: Click here
How to upgrade the M11S: Click here
Dec 28, 2022 at 9:18 PM Post #264 of 641
I found the option, but it seems not to work.
Dear friend,
I failed to locate the issue but I got the same phenomenon in my mobile phone as well. Maybe the full screen mode in this app not mean the full album cover.
Best regards
Dec 29, 2022 at 1:31 AM Post #265 of 641
How do I use Roon, and have the music be "Bit-Perfect", with the update? @FiiO
Dec 29, 2022 at 7:55 AM Post #266 of 641
Just make sure you add the device in Roon settings -> Audio to use the "Roon Ready" configuration and player. Of course, the "FiiO Roon" feature needs to be enabled on the DAP as well. It works perfectly on my M11 Plus.
It can be a bit confusing as the M11S will show up twice (once as a local player - not bit-perfect, and again as a "Roon Ready" player).
Dec 29, 2022 at 8:26 AM Post #268 of 641
Dec 29, 2022 at 10:25 PM Post #269 of 641
Hmm, it is not working for me
Can you show screen shots to get it to work?
Dec 30, 2022 at 7:30 AM Post #270 of 641
