New FiiO M11S Player with dual ES9038Q2M DACs, 670mW output power and 14 hours of battery life
Dec 12, 2022 at 4:42 PM Post #227 of 642
Ah OK. Well what a shame. Lol
Can I change the color temperature of the display?
Dec 13, 2022 at 12:19 PM Post #230 of 642
How would you rate the SQ of the M11S compared to a Dongle like the EarMen Sparrow/Colibri or Questyle M15 fed by a smart phone. I'm still trying to classify things before going into the market.
Sparrow is thinner, leaner sounding and a touch more bright.
The M15 and Colibri are quite close and maybe a little more organic.
But none of them can touch the dynamics and fuller sound of the M11S
It is bigger, bolder and more expansive.
More powerful and better grip for headphones.
Better power supply and the extra electronics inside it pay off.
It is also more silent with a blacker background but the Colibri is also quite close.
What you have to ask yourself is what kind of use are looking for and then decide.
But this is a rather vague discussion because there are so many products to add like the BTR7 or the iFi Go bar etc....
Dec 13, 2022 at 1:15 PM Post #231 of 642
Thank you for your opinion. This is indeed not easy for me. In principle, I would like to have a portable system that I can use in bed or on business trips in the evening at the hotel. So it doesn't have to be very mobile. But it should sound as good as possible. Price range would be about 500-600€. So far I always thought with the smartphone and a Colibri or even Mojo 2 you have a good or for the price the best system for IEM's without the battery is too fast empty.
With the topic of DAP I have never dealt but must say that I like the idea (1 device and all apps like Qobuz, Spotify Audio Player Pro, etc.)
Dec 14, 2022 at 11:55 AM Post #232 of 642
I Need some help here.
Received my M11S yesterday. I‘ve put in an SD Card : 256 GB SanDisk Extreme V30 Brandnew. Formated it inside the player as external Memory an put some files on it.
Folder: Music/Flac/Artist/Album/01 track
Using the Fiio Music App brings a „Stutter“ After the First few second of each track. Always the same regardless of highres or redbook quality.
With the Apple Music App there is No such stutter.
The stutter ist really disturbing while listening to music and playing music via Fiio App should be a Basic feature, so I guess I‘ve done something wring here. But I dont‘t know what it could bei
I had similar problem. Solved by copying the files back to the micro SD card. I don't know what happened, but it seems to me that the files got corrupted for some reason. However, I had a certain problem in starting some tracks of a CD that extract the songs in FLAC.
Dec 14, 2022 at 2:41 PM Post #233 of 642
So, I have had the FiiO for almost a week; before, I would have said DAP break-in was not a thing, but it is! The more I listen to the M11s, the wow!
Dec 17, 2022 at 10:29 AM Post #236 of 642
When using Apple Music on the FiiO M11S connected to my DAC Topping D70S, I noticed that the resolution of the files shown on the D70S display does not change according to the music being played. Any explanation for this @FiiO ?
Dec 17, 2022 at 10:32 AM Post #237 of 642
Apple Music is not bit perfect unfortunately. It never changed resolution once it sets to the first resolution. I am waiting for a solution from Fiio.
Dec 18, 2022 at 2:32 AM Post #238 of 642
Unfortunately, unless you use an Apple product, there is no default "bit perfect solutions" sorry. This is both on Windows and on Mac.
Dec 18, 2022 at 8:40 PM Post #239 of 642
@FiiO Can we turn on the power button light?
If you take a look at the player, you'll see that it doesn't actually have a power LED at all...
Dear friend,
Yes, the power button of M11S does not have the LED indicator. So there is no light for the power button in M11S.
Best regards
Dec 18, 2022 at 8:40 PM Post #240 of 642
Dear friend,
We have reported this issue to the engineer for checking first. Sorry for the inconvenience.
Best regards
