New FiiO M11S Player with dual ES9038Q2M DACs, 670mW output power and 14 hours of battery life
Dec 19, 2022 at 2:20 AM Post #241 of 641
@FiiO I have had a few glitches where I have been using Qobuz, and the app will display the correct resolution, but the player will be "stuck" in a different" one. I have quit the app, and restarted Qobuz, and it will still be "stuck." The only fix I found was to continue the player.
Hello all, has anyone noticed a dramatic shift in clarity and definition after 25 or so hours of playing?
Dec 19, 2022 at 5:39 AM Post #242 of 641
@FiiO Tive algumas falhas ao usar o Qobuz e o aplicativo exibirá a resolução correta, mas o player ficará "travado" em uma "diferente". o aplicativo e reiniciei o Qobuz, e ele ainda estará "travado".
Try the USB Audio Player Pro (UAPP) app. I had no issues with this app having the ability to access Qobuz.
Dec 21, 2022 at 5:30 PM Post #244 of 641
@FiiO When playing songs from the FiiO Music app on M11S, I noticed that only the folders that have a file with the cover image are suffering from freezes during the playback of the songs. When playing songs in folders that didn't have an image file, the quick freeze issue didn't occur.
Dec 21, 2022 at 7:10 PM Post #245 of 641
Thanks for the input. I will try this out from my end.
Dec 21, 2022 at 7:17 PM Post #246 of 641
Hello all! I am new to this forum! Just purchased and tested my first hires player, Fiio M11S. Unfortunately, as the case with previous models, Amazon Music HD is not working at all. Just complete silence. Deezer streaming works fine. Did not test any others. Player also reads and plays all the FLAC files on the SD card.
Just signed up for Amazon Music and wanted to revive this prior post to note that it works fine for me on the M11S.
Dec 22, 2022 at 9:07 PM Post #248 of 641
Dear friend,
What's the format of your cover image? And what size is it? Thanks in advance!
Best regards
Dec 27, 2022 at 1:24 AM Post #253 of 641
@FiiO Can the image on the Qobuz app go full width compared to now?
Dear friend,
It seems that I failed to find this option in Qobuz. Can you get it work in other device? If yes, you could try the same method for help.
Best regards
Dec 27, 2022 at 2:25 AM Post #254 of 641
I found the option, but it seems not to work.
