holden4th
Hi all,
I've been the happy owner of a pair of Atlas for a few days now. I don't consider myself an audiophile and don't know much about the proper audiophile vocabulary or technical terms to describe what i hear (specs, ranges etc..) However, i'm a professional orchestra and opera conductor across the world, and i can tell you that when i listen with the Atlas to a performance that's been recorded (with good equipment and technique), it's sounds just about the same as what i hearing standing on the podium when i'm conducting. So it's a great tool for me.
I've been playing around trying to find the best tips for fit, confort and of course SQ. I've been trying 4 different types of Comply foam tips and i have a question about bore size and fit.
Since the atlas have a pretty wide bore, i've ordered a bunch of 500 and 600 from Comply. The 500 fit well (tried the confort+, the isolation+ and both works) The 600 are too wide (the sport + and isolation), they to hand tight enough to the nozzle of the iem.
I've heard a lot of people talking about the Spinfit, and would love to try them, however, i don't know which model should i order to get the proper fit on the nozzle. Has anybody tried them ?
Would the CP-100 (which seems to be the most common one) fit or will it be too tight ?
many thanks
If you want a wider bore then go for the JVC Spiral Dots which have a bigger bore than the Spinfits.
