It's what I use too with the Comet
duo density symbio tips?
Would you not use a 2.5mm to 3.5mm SE plug to avoid changing cables that could wear out the MMCX. I know the Beryllium-Copper connectors are pretty good in this kind of usage. But its less one cable to bring around.I use the standard cable for 3.5 SE plugs
Do you have to go one size smaller than your normal fit? Meaning you are using Mediums on normal silicone tips. So Symbio W is the right fit for the Atlas then.Okay, I have found my new favourite tips for the Atlas, small mandarin symbio wide bore tips. They provide the same isolation as Marshmallows/Comply with no dampened mids.
I actually use large for normal silicone tips, before foams, large spinfit provided the best seal but had very bad driver flex (even continuing on after removing the earphone from my ear). The foams on the medium Mandarins are a bit stiff so they eventually hurt my ears, large Mandarins are just way too large. I think my earholes are kinda wide but flat? idk how to describe it.
Try going down a size to small for the mandarins? A lot of people on the dedicated thread have commented on the fact that they use a smaller size than normal for these tips.
I've had to put my comets away until my custom tips arrive (another 2-3 weeks yet ) It's not so much finding a size that fits for me, it's the stupid angles of my ear canals. After getting impressions done my left ear is relatively straight, but my right ear has quite a rise in it. Even spinfits don't help.
So true. I used to stick with well known prosumer brands like Audio Technica, Sennheiser and realise there's a whole new world of boutique houses that makes innovative stuff.ugh, guys i need advice. I purchased the Vega yesterday for $1000. Kinda new audiophile (considered myself one because I had an ie800 but over the last week of hard research i realize there’s a whole another world out there and i’m so excited and passionate about campfire)
so here, i’m wondering if i should return and buy the atlas although there’s a 15% restocking fee or do you guys think there could be a chance i like the vegas more?
IMHO the only time where you might like the Vega more is the wearing style and fitting. This would highly depend on what kind of style you prefer: cable up/over ear or cable down (e.g. you hate memory wire). Both styles have their advantages and disadvantages. The Atlas is designed primarily for cable down and many people actually do wear earbuds this way. However, Atlas being very heavy has a tendency of being pulled down and loosing seal. Even the stock cable which is very light to begin with has sufficient pull down force to do this. Many of us tried to wear it upside down so that the cable can go over ear with various degrees of success. Go back a few pages and you will see some of us discovering new ways of wearing IEMs (don't laugh because it works). The stock cable is soft and flexible enough for this. Alternatively if you like foam tips, you won't have any issues. For me wearing cable down provides the best seal and hence good bass response but I need to adjust my left ear every few seconds so that is impractical. Atlas also has driver flex and it happened to many of us. This is very tip dependent. For me wearing cable up in combination with the included Final Tip E removed 95% of occurrence. The good thing about Atlas is that it has very strong bass that it still performs even if I couldn't get the best seal. Silly thoughts yes.somehow as i sit here, enjoying the vegas i have a burning desire to get the atlas. what do you guys think? should i return the vegas for the atlas? (the 15% restocking fee isn’t a problem)
IMHO, yes. Atlas's bass is more 'connected' and 'emotions driven'. Its like hearing it from a good set of speakers vs hearing it at the place music is being played by actual musicians. It also 'clearer' than Vega at the high end. I don't have sufficient experience in articulating this but to put in on layman terms. Atlas was able to perform really well like a BA what DD can't reproduce on a Vega high end wise.is it true that the atlas is just vegas 2.0? does it do everything the vega does but better? can someone help clarify? how does the bass compare? does the atlas have bigger bass? and does it give you that nostalgic feeling that vegas delivers! is it clearer that the vega but also just as bassy?
Have anyone tried continental V5 with Atlas? I am planning to pair Hugo2(as DAC) with CV5 for Atlas. : )
blessing in disguise that i lost my ie800 which led me to discovering the Vegas at a shop in NYC (liked them much better than Andros/but still loved the andros but went for the vegas bc i listen to mainly edm)
thus, like the noob I am, somehow i didn’t notice the atlas (goddamnit i’m so oblivious)
i love love love the clarity that the andros have and the soundstage but the vegas made me feel the music and that’s something science and technicality can never accomplish
much much appreciated!
