Sep 21, 2012 at 3:20 PM Post #31 of 34
what version has one?
I do not know of any commercial pre-assembled version that has one as a standard feature, they generally follow the same reference design. You would likely need a custom/DIY build, or modify one yourself. It would probably be best to ask for information on this on the diyAudio forum. However, the simplest solution is to buy a separate O2 and ODAC. That is slightly more expensive, but it also allows to keep the option of using the O2 from battery power.
Sep 21, 2012 at 7:15 PM Post #32 of 34
I may get the HRT music streamer II with the O2. I would get the little dot mkIII but the shipping is $50... anyone know any alternatives to buy it from?
Sep 22, 2012 at 3:46 PM Post #33 of 34
bump.
Sep 23, 2012 at 9:54 PM Post #34 of 34
Just get an O2 + ODAC from JDS labs.
