Dixter
- Dec 21, 2011
has anyone here made their own cables for their ADs? i'm making a lightweight travel cable and have most of it done, but haven't soldered the ends to the adapters (the parts that attach to the earpieces) because i can't figure out which terminals to connect. on the mrspeakers site he gives the wire configuration for L and R: https://www.mrspeakers.com/MrSpeakers-Alpha-Dog-Headphone
but if i have two wires going to each cup and there are four pins in the connector part, which pins should i solder to? the pins are not numbered as far as i can tell...i feel like there's something simple that i'm missing.
any help would be appreciated. thanks.
If you get confused use the Ohm Meter Luke...
Just ohm out the original cable and duplicate the connections on your new cable...
after you solder the new cable make sure you check the connection of + and - to make sure you have not created a short circuit...
