Ableza
I drove my Alpha Primes with a Lyr 2 (and also used Gold Lions) and loved it. Yes, your DAC is absolutely your weak link. Try one of Schiit's multibit models.
Thanks for the advice! I wonder if the Bifrost Multi is worth the price difference of the Modi Multi in the sound department? There is about an 80% chance that I will probibly never upgrade the Bifrost if I would have to send it back to Schiit to do so like people had to do to upgrade to the multi due to firmware reasons.I drove my Alpha Primes with a Lyr 2 (and also used Gold Lions) and loved it. Yes, your DAC is absolutely your weak link. Try one of Schiit's multibit models.
I can't answer your question about Bifrost VS Modi, but my advice is to buy what fits into your budget.Thanks for the advice! I wonder if the Bifrost Multi is worth the price difference of the Modi Multi in the sound department? There is about an 80% chance that I will probibly never upgrade the Bifrost if I would have to send it back to Schiit to do so like people had to do to upgrade to the multi due to firmware reasons.
Since the Modi is less than half the price of the Bifrost, I may just try it instead. I don't know what I would be missing with the Bifrost anyway and the Holidays are about to hit my pocket book! LoLI can't answer your question about Bifrost VS Modi, but my advice is to buy what fits into your budget.![]()
