veracocha
- Jul 26, 2006
How Can I update firmware without sd card ?
i don't care about the lib update anymore i gave up
but JAMES i want u to know the features that i'd like to have in my x3 to make it more perfect (no. means priority)
NO.1: ID3 Tag lyrics. lrc files that x3 uses are so hard to get. I really really need this feature
(maybe ID3 Lyrics could pop up when double clicking back button)
NO.2: How come X3 only reads album arts less than 100kb jpg files. . i hope it could read more
NO.3: Since i have many songs it's hard to find it so how bout double clicking downwards makes one page ahead?
well you can forget about NO.2 or NO.3
BUT I RELLY NEED NO.1
Does the manual update take a long time, and then you have to reset the device? If so, you have probably reached a limit based on the number of tracks which you can work-around by adding a few hundred to the SD card at a time and doing a manual update between each tranche. If the update isn't crashing, but the tracks aren't appearing, your database is probably corrupted and you need to delete it and recreate from scratch. JamesFIIO created a thread with a how-to for this - I'll add a link in a moment if I find it before you....
It's here:http://www.head-fi.org/t/681416/how-to-delete-the-database-in-the-x3-disk
I got my X3 a couple of weeks ago and am enjoying it immensely. Am making do with the 8gb storage that comes in-built! And seeing the issues in this forum I was reluctant to buy a 64gb memory card! But then I didn't want to end up with an X3 with 8gb storage! So I took the plunge and against my better judgement went in for 64gb card as against a sensible 32gb micro sd card. I've now spent the best part of 2 hours and am yet to format the msdc to fat32! Shall try once again and update the results!
OK, so I ordered the same Sandisk 64GB card that others in this thread have found to work well (Ultra microSDXC UHS-I). I formatted it to FAT32 successfully and proceeded to fill it with a variety, but largely 24bit FLAC files, so not a huge number. The X3 does not recognise the card and a reset does not help. Under browse it says File not playable and under info it reports availability as 0. However, when connected to USB with the card inserted it shows up correctly and all files are accessible. There are no filesystem errors on card or internal storage.
Is this something that is likely to be corrected in a forthcoming firmware update or does it indicate that my X3 is faulty?
Update - I have now reformatted the card, this time using SmartDisk_FAT32_tool (the second link in the previous post) and all appears well. Now to fill up again...
this part here...ugh!
