morndewey
- Mar 15, 2016
Thanks dude
Thanks dude
Just ordered a set from Ali. For the price it’s easy to experiment. ThanksSFR **** are incredible. Better and more enjoyable than Crescents for me, but quite warm and rounded. Lovely mids.
They are amazing! Dont use the weird red tips they come with though. Foams / a good fit and you will find one of the best 'budget' IEM's currently out there
What do you mean a new version of ****?No, definitely don't use those tips. The right fitting foams for you will give a really rich, euphoric yet detailed experience. I'm not going to overplay these anymore as everyone's preferences and experiences are personal...but I think you can detect my enthusiasm for these. The good place for the new version of **** on Ali is LuckLZ (no, I don't have shares!!)...a nice guy and helpful.
new version of **** NOT dM6What do you mean a new version of ****?
Yeah, ****. The 'newer' version has a better braided cable (not that it's that brilliant!) and a nicer, shiny black shell.new version of **** NOT dM6
waitttt. i post my impressions on that few weeks back. looks like i got the 'new version' one, didn't know that they have 2 versions
I actually did that on one pair. I removed the metal mesh and tried using them like that. It didn't change anything. Under the metal mesh there was another finer mesh which looked like smooth fabric. I was afraid of ruining them so I didn't try to remove or poke that fabric but my guess is that is that fabric was the culprit. Today I sent both of my pairs to seller and I will be refunded. As I was at the post office I realized I am sending away my last headphones I have and I can't be without headphones for a month till new arrive. So I wen't to the city looking for some cheap well known headphones I could buy right now. I found for 10$ real Samsung eo-ig955 (Samsung IEMs tuned by AKG). They are useable but I still wanna buy something better. I guess I try **** ****.Since you've got already 2 pairs, I'd rid of the stock mesh in one pair and replace it for another mesh with bigger "pores" just to make sure it isn't the culprit after all. (Or you can DIY one using 3M micropore, alcohol swab, tea paper, etc...)
https://www.aliexpress.com/item/Dus...?spm=a2g03.10010108.1000001.12.515c15c8taX7ck
Hello you guys! I just got KPE and LG v20 after having se215 and nothing (pixel), respectively. Absolutely love the kpes, they are unbelievable. I sometimes wonder if it's possible for the sound to be any better than that. I am a layman in audiophiles' terms, but after hearing instruments right behind my ears I can surely say that the soundstage is hella wide
I have a small problem tho: my ears are oddly shaped... They have not canals, but craters with golf holes. Thus, I need either the absolutely biggest ear tips for the craters or the absolutely smallest ones for the holes (I doubt tips are made that small tho). Also, silicone just slides in there, so I preferably need some foam. Finally, some isolation would be nice.
I ordered comply active foam tips, but the size was medium. Are there any more options in case the said don't fit? Preferably some cheap memory foam with decent isolation from aliexpress.
Thank you
What an amazing IEM to start with ! o_0 Hearty congrats
Which part of the world do you live in ?
