tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
The one thing I was wondering is if I used an all plastic box then just used the perf board as the the central grounding point would that be bad? I basically bought one of these and it has a metal top and a plastic top I was back and forth about how to do grounding thinking that it might be better to mount to plastic and then have the grounds all go to the perf board. I guess It's something I can always re-work if it doesn't work out well.
There is no ground plane or solid plate on that perf board. The pads are simply tied together with traces in certain instances. It's not the same thing as a ground plane or plate. There are other issues, as well. I apologize for continuing to harp on it, but seriously - you have two tube sockets with 14 connection points and two MOSFETs with 6 connection points, plus heat sinks that have to be mounted. None of those will work on the perf board. In addition, you have four caps - perhaps eight if you use the bypasses - that will span 3 to 5 of those holes in the perf board with their leads, much less the physical size of the caps' cans themselves. You also have 5 components in addition to this that all need panel mounting. In addition to the tube sockets, MOSFETs and capacitors, that represents another minimum of 13 leads going from those components to somewhere on the perf board, perhaps several more than that. At some point, having a little board with holes in it doesn't give you much advantage.
Like I said the last time, draw it out. This isn't the Starving Student, but it might give you some ideas with that perf board: http://benfeist.com/wp-content/uploads/2012/12/a47_assembly_and_schematic.png
If you can make it work - fine, but I have doubts. Good luck.
